Browse Forums Pools & Spas 1 May 03, 2017 11:12 pm Hello, I'm planning to build a 4m x 8m pool in Brisbane. I've read about possible heating options (gas heating, heat pump, solar heating via a net of tiny tubes on the roof) but this all feels complex to me and I'm wondering if there is an option to heat the pool in the same way a kettle boils water? I have a large roof that that I can cover with solar panels. Am I missing something basic here? Thanks! Re: Can I heat a pool using a heating element? 2May 03, 2017 11:19 pm Old school heaters used a element like a kettle . Using one on a pool that size would result in a power bill around $2000-$3000 per quarter . A good solar system would allow swimming from September to may in brissy . If you wish to use the pool in winter you will need a heat pump or gas heater. Re: Can I heat a pool using a heating element? 3May 03, 2017 11:34 pm Ok, so I'm not entirely crazy .Would I have such a big bill even if I heated the pool only during the day when energy comes from solar panels? Re: Can I heat a pool using a heating element? 4May 03, 2017 11:40 pm You would need a large solar system to power one . They are also quiet slow heating . I would recommend a electric heat pump if you have solar panels. A heat pump is about 6 times more efficient than a element heater. Re: Can I heat a pool using a heating element? 5May 04, 2017 12:10 pm Makes sense, 1:6 ratio is I suppose why it is not widely used. Thanks! Re: Can I heat a pool using a heating element? 6May 04, 2017 2:36 pm Gas heating great to heat quickly but big $$$ to use it .. i ensed up foing heat pump and ran it during the day with pumps which my solar power 5.5 kw system ran the heater and pumps during the day costing me nothing plus i have it set to off peak at night if need be costing me 7 cents and hour .. So heat pump if you have a solar system already install .. let the sun pay for it Only go gas IF you intend to have a spa cause you need to heat it quickly otherwise i recon heat pump all the way Re: Can I heat a pool using a heating element? 7May 04, 2017 10:19 pm Yeah, it looks like a heat pump is the right solution for me. I wanted to avoid it as they are big and ugly. Re: Can I heat a pool using a heating element? 8May 05, 2017 10:17 pm Hi, You Wrote "I have a large roof that that I can cover with solar panels. Am I missing something basic here?" Are you CRAZY? The old style kettles had a lock in mechanism to avoid electric shock/electrocution! AKA Death. And you want to swim in it? Maybe the mother-in-law I can understand. The process a kettle heats water, is by for a better term "Short Circuits" a wire which glows red hot in order to boil water. This is VERY EXPENSIVE in electricity price, however for a smaller body of water such as a kettle, this is overlooked and speed is king. However, if we are talking about a body of water the size of a swimming pool (40,000 litres of water and nor 2 litres, that of a kettle) ........... Then this method would be, for a better word. MADNESS. My recommendation to you with solar panels would be to use a "Heat Pump" system. Please read my review of pool heating systems as one of the other option would better suit your lifestyle. Cheers, Andrew Here is my Story ..... viewtopic.php?f=65&t=73509 Re: Can I heat a pool using a heating element? 9May 05, 2017 10:22 pm Here is my Review, of different types of Swimming Pool Heaters which I should have linked instead. viewtopic.php?f=65&t=87715 Cheers, Andrew There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 3952 Shade the brick with large eves. Since going to minimum of 600mm eaves on my build, I've noticed much improved cooling off the house after hot summer days. Can see the… 1 4721 Also at the bottom of page 4... ...and from 28 November 2023 a heat pump water heater, gas boosted solar water heater or electric boosted solar water heater can be… 9 1342 |
