Browse Forums Owner Builder Forum 1 Mar 05, 2011 8:31 pm Our carpenter has asked us to mark out the wall studs on the floor, so to help him when installing skirting boards. We were planning on first painting the walls, then installing the timber flooring and then having the skirtings installed. What is the standard way of marking out the wall studs? I was thinking of marking on the floor, then once Walls are painted put stickers on the walls. Does this sound like a good idea or are there better ways? Re: Marking wall studs for skirting boards 2Mar 05, 2011 9:06 pm Mark a line on the wall about 40mm up from ground. You don't need to paint this low as it will be covered by the skirting so you will still see the mark after painting and floor. Your chippy should be able to work it out from there. Or just stick a piece of masking tape to wall higher up if necessary before he gets there. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Hi All. I'm currently resurfacing the hardwood floors and when removing the old layers that there's a long dark line running across the boards. Does anyone know what or… 0 15054 Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 653 |
