Browse Forums Eco Living 1 Sep 23, 2010 6:02 pm Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Re: How to hook in a 2nd tank? 6Dec 10, 2010 2:12 pm Connect the overflow of the first tank to the second tank and then connect the overflow of the second tank to the drain. When the first tank is full it will then start to fill the 2nd tank. Because you will get settling in the first tank this way means 95% of the dirt will stay in the first tank so only one lot of cleaning The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 1503 Regardless of the trees route undermining your footings and slab or not. Trees need to be away from the buildings as per the BCA requirements below otherwise the design… 1 520 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 18037 |
