Browse Forums Home Theatre & Automation 1 Nov 11, 2008 3:15 pm Hi All,
I want to be able to control my amp via my PC. I have got the usb to RS232 port working (ie. serial port) i have the codes to my amp (Onkyo) but i don't have a good application (front end) to get it all working. Any recommendations? Girder seems to be the only program i've seen but it doesn't support linux plus it costs $$$ Any help is appreciated. smeags PS i'm running Mythtv as well as Vista MCE. ---->Some say that a recession is when your neighbour loses his/her job while a depression is when you lose yours!<----- Re: Controlling your Amp via RS232 2Nov 11, 2008 3:31 pm smeags,
try the xpmediacentre forum on this one. I doubt you will get a huge response here! Re: Controlling your Amp via RS232 6Nov 13, 2008 1:36 pm Snake Use SecureCRT you can download it off any P2P site. Hi Snake thanks for the suggestion. I had a look and this just looks like putty.exe and that is free I think I found the answer here http://www.byremote.com.au/ and its free too so will give it a try this weekend. The main reason i am doing this is i want to have all my AV equipment outside of my home theater room. Right now i can control my mythtv box via my iphone using wireless lan but i can't find a away to control my amp yet, if can get it to work it would be perfect..no noise in my HT room. ---->Some say that a recession is when your neighbour loses his/her job while a depression is when you lose yours!<----- Re: Controlling your Amp via RS232 7Nov 13, 2008 1:39 pm smeagol Snake Use SecureCRT you can download it off any P2P site. Hi Snake thanks for the suggestion. I had a look and this just looks like putty.exe and that is free I think I found the answer here http://www.byremote.com.au/ and its free too so will give it a try this weekend. The main reason i am doing this is i want to have all my AV equipment outside of my home theater room. Right now i can control my mythtv box via my iphone using wireless lan but i can't find a away to control my amp yet, if can get it to work it would be perfect..no noise in my HT room. Putty is excellent, but SecureCRT has scripting features which I luv. Re: Controlling your Amp via RS232 8Nov 13, 2008 2:46 pm Why not use IR repeating??
Much cheaper and easier! Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40799 Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their… 2 46355 The worst thing you can do is sign a building contract without a pre contract review. Over the years many people have come to me with disputes where they just signed… 0 8769 |
