Browse Forums Home Theatre & Automation Re: "BIG" HOME THEATRE ROOKIE "HELP" 21Feb 26, 2011 1:05 pm hi Pedro, the calculator says that the projector should be between 3.8m and 5.1m from the screen. I'd have it at about the 5m mark. Rodda may have a different opinion. I'd like to hear from him on this one too. SK Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: "BIG" HOME THEATRE ROOKIE "HELP" 22Feb 26, 2011 2:02 pm cool. the reason i ask is i have been told that if you can get the position as close to not having to focus the lens is the best result even if you have to tweak it a little is ok but too much tends to result in poor performance. stud to stud on the plans from front to rear is 5350mm so i am thinking 5m back should do the trick and allow for a good range of projectors to choose from? this is of course looking at the calculations you put up? https://forum.homeone.com.au/viewtopic.php?f=36&t=37134 THE THREAD https://forum.homeone.com.au/viewtopic.php?f=31&t=35962 THE BLOG! http://pedrosinspiredbeauty.blogspot.com/ BRICKS BRICKS ARE FINISHED... ROOF STARTS TODAY 03/02/2011!. Re: "BIG" HOME THEATRE ROOKIE "HELP" 23Feb 26, 2011 2:17 pm I think that would be fine Pedro, Most modern projectors have the ability to change the throw distance quite a way. As an example, the Epson TW3600 for a 110inch diagonal can be placed between 3.3m and 7 metres away from the screen. Focus can also be adjusted at any distance so it shouldn't be a problem either. SK Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: "BIG" HOME THEATRE ROOKIE "HELP" 24Feb 27, 2011 1:51 pm Is the house single or double storey? If it is single storey then I would not be too concerned. Make sure the HDMI cable is long enough to hang down through the ceiling and to the projector. In this case I would say a 10 metre would be suitable. The power point should be mounted inside the ceiling and the cable can be run down the projector mount (concealed) for a custom finish. Of course if it 2 below a second storey this is different! Re: "BIG" HOME THEATRE ROOKIE "HELP" 25Feb 27, 2011 2:16 pm Hi matt, it is a 2 story, the electrician has allowed for a 10mt HDMI cable. I dont know what his plans are for the power but i will confirm it. thanks https://forum.homeone.com.au/viewtopic.php?f=36&t=37134 THE THREAD https://forum.homeone.com.au/viewtopic.php?f=31&t=35962 THE BLOG! http://pedrosinspiredbeauty.blogspot.com/ BRICKS BRICKS ARE FINISHED... ROOF STARTS TODAY 03/02/2011!. Re: "BIG" HOME THEATRE ROOKIE "HELP" 26Feb 28, 2011 8:27 am If you settle on a projector then you can visit the maker's web site and use their projector calculator to determine the distance/range for it. If you have not settled on a projector then for a 100" screen I'd say the average projection distance is about 4m, and if you get an LCD (or a JVC D-ILA for that matter) they have a fair zoom range so you won't get caugth out. Re: "BIG" HOME THEATRE ROOKIE "HELP" 27Feb 28, 2011 2:22 pm actually i have seen the Optoma HD20. Any thoughts? tick or cross https://forum.homeone.com.au/viewtopic.php?f=36&t=37134 THE THREAD https://forum.homeone.com.au/viewtopic.php?f=31&t=35962 THE BLOG! http://pedrosinspiredbeauty.blogspot.com/ BRICKS BRICKS ARE FINISHED... ROOF STARTS TODAY 03/02/2011!. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 18372 Hey everyone, With winter just around the corner, I'm starting to think about how to prepare my home and garden for the cooler weather. Winters can be a bit surprising,… 0 1623 |
