Browse Forums Building A New House Re: Building with Hall and Hart 8Sep 25, 2018 12:59 pm Hi nasreen45, great to hear another HHH build! Here is the other thread - viewtopic.php?f=31&t=89920 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8820 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 |
