Browse Forums Building A New House Re: Building with Hall & Hart Homes 1001May 14, 2020 11:39 am Zen, that alfresco roof looks fine to me! Thanks for asking the question though Ocean. Thanks for sharing Zen re stair lighting. One per landing sounds good, we have a big stair window, but given lighting is for night need to think about this. Are these sensor or light switch? Re: Building with Hall & Hart Homes 1002May 14, 2020 11:54 am msresearcher Zen, that alfresco roof looks fine to me! Thanks for asking the question though Ocean. Thanks for sharing Zen re stair lighting. One per landing sounds good, we have a big stair window, but given lighting is for night need to think about this. Are these sensor or light switch? The stair lights are on a 2-way switch for up and downstairs. Didn’t consider operating via sensor - that would be a cool option Re: Building with Hall & Hart Homes 1004May 15, 2020 3:52 pm ks155 msresearcher Double glazing with the optimal gap is gold standard though.And low e in between would also not have the issues of low e in single glazing. Thank you for your comments. It gave me a lot to think about. We got our quote to do low e glaze for windows about 50m2 area to our house. It's around $7500. We have to do this due to BASIX requirement Re: Building with Hall & Hart Homes 1005May 15, 2020 6:35 pm ks155 ks155 msresearcher Double glazing with the optimal gap is gold standard though.And low e in between would also not have the issues of low e in single glazing. Thank you for your comments. It gave me a lot to think about. We got our quote to do low e glaze for windows about 50m2 area to our house. It's around $7500. We have to do this due to BASIX requirement Ask them to go back and ask for a better option, by adding different things (more economical or better value for money) sometimes the low e can be reduced dramatically sometimes to Zero Re: Building with Hall & Hart Homes 1006May 16, 2020 2:50 pm Hi All, needing some advice with similar experiences. For the plans acceptance phase, how critical is it to 'get it right' in the drafted drawings vs what they're agreed in written responses to update in drawings. I am just worried the contractors on site will follow drawings in lieu of builder's advise back to us in a separate document. Eg. Tiled hob perimeter to balcony as per display home upgrade, unfortunately final draft still shows none. As you can imagine, I'm hesitant to part with our 10k but wary it will take more weeks as it already took this long enough to get to this point. Is this the time to be 'fussy' or is there another construction set of drawings to sign-off. Thanks again. Re: Building with Hall & Hart Homes 1007May 16, 2020 3:04 pm HaminZa Hi All, needing some advice with similar experiences. For the plans acceptance phase, how critical is it to 'get it right' in the drafted drawings vs what they're agreed in written responses to update in drawings. I am just worried the contractors on site will follow drawings in lieu of builder's advise back to us in a separate document. Eg. Tiled hob perimeter to balcony as per display home upgrade, unfortunately final draft still shows none. As you can imagine, I'm hesitant to part with our 10k but wary it will take more weeks as it already took this long enough to get to this point. Is this the time to be 'fussy' or is there another construction set of drawings to sign-off. Thanks again. Drawings at estimation only help them get the tender estimation to you. Construction phase is based on architectural drawings which will only be done post tender acceptance. You can expect to see a tender line item with pricing for the tiled hob perimeter. This will then make it's way to the plans. Plans will change quite a few times until they're ready for DA. So don't be worried as you'll be asked to sign off plans for DA and can question anything you paid for which is not reflected in plan. If structural it will be on plan. If it's a certain finish it'll be in your colour selections document Re: Building with Hall & Hart Homes 1008May 16, 2020 10:03 pm SDS1 HaminZa Hi All, needing some advice with similar experiences. For the plans acceptance phase, how critical is it to 'get it right' in the drafted drawings vs what they're agreed in written responses to update in drawings. I am just worried the contractors on site will follow drawings in lieu of builder's advise back to us in a separate document. Eg. Tiled hob perimeter to balcony as per display home upgrade, unfortunately final draft still shows none. As you can imagine, I'm hesitant to part with our 10k but wary it will take more weeks as it already took this long enough to get to this point. Is this the time to be 'fussy' or is there another construction set of drawings to sign-off. Thanks again. Drawings at estimation only help them get the tender estimation to you. Construction phase is based on architectural drawings which will only be done post tender acceptance. You can expect to see a tender line item with pricing for the tiled hob perimeter. This will then make it's way to the plans. Plans will change quite a few times until they're ready for DA. So don't be worried as you'll be asked to sign off plans for DA and can question anything you paid for which is not reflected in plan. If structural it will be on plan. If it's a certain finish it'll be in your colour selections document I read that they are at plan acceptance phase not tender acceptance phase Re: Building with Hall & Hart Homes 1009May 17, 2020 8:28 am HaminZa Hi All, needing some advice with similar experiences. For the plans acceptance phase, how critical is it to 'get it right' in the drafted drawings vs what they're agreed in written responses to update in drawings. I am just worried the contractors on site will follow drawings in lieu of builder's advise back to us in a separate document. Eg. Tiled hob perimeter to balcony as per display home upgrade, unfortunately final draft still shows none. As you can imagine, I'm hesitant to part with our 10k but wary it will take more weeks as it already took this long enough to get to this point. Is this the time to be 'fussy' or is there another construction set of drawings to sign-off. Thanks again. Im not exactly sure of this either. Wary of once you pay the 10k, then other changes are 1k a pop. But they have assured me more than once that changes resulting from your landscaping plan, cdc/da required changes, and interior selection, changes don't cost us to update plans. And obviously electricals too, we haven't got to that phase. But like you i would want to be 100% sure the plans are accurate before construction starts! I'm fully expecting my kitchen, laundry, butlers layout will change post those detailed design phases. i also want to change some door widths and shower types, havent even thougt about the 3 WIRs (use elba or do post handover), want to put a chute in - i was told that's in interior selection phases. Things like missing niches etc that were on tender plans but not proper plans now ive gotten put on. And anything clearly wrong, asked to be fixed. If i was you id insist on anything structural being in now, but not tile choices maybe. Not sure i know what a tiled hob is sorry lol to know if crucial to get in plans now or not (our dwarf walls on alfresco are in plans now if that helps). The only thing showing on my plans now is glazing and window upgrades, waterfalls, recessed flooring, ledges etc. Not other fixture and finishing selections i have. Like I have a flooring provision, but it still shows tiles on the plan...I guess as I haven't locked down that selection. It is frustrating that we turn plan comments around in 1-2 days and they take weeks. But so far they've been great to deal with so Im happy everything is nice and relaxed. But i thought I had the longest tender in the world, but now im actually wondering if i will make tender expiry date! Re: Building with Hall & Hart Homes 1010May 17, 2020 8:56 am Hi all Can I have some advice. Im in a loop of how to pick tiling before kitchen or vice versa. They seem to suggest tiling first, then kitchen later (towards end). I am unsure if I will go a standard included silestone bench top or upgraded (depends on upgrade cost!). My tiling choices for floor and splashbacks are completely different depending on which the 2 bench tops I go with for kitchen/laundry/butlers. Can you go back and change your selections if a later decision unwinds an earlier one? Or maybe I should just do kitchen design before tiling? Argh. Trying to get organized but I feel like too many decision points and I am unnecessarily mocking up two different pallets. Re: Building with Hall & Hart Homes 1011May 17, 2020 9:23 am msresearcher HaminZa Hi All, needing some advice with similar experiences. For the plans acceptance phase, how critical is it to 'get it right' in the drafted drawings vs what they're agreed in written responses to update in drawings. I am just worried the contractors on site will follow drawings in lieu of builder's advise back to us in a separate document. Eg. Tiled hob perimeter to balcony as per display home upgrade, unfortunately final draft still shows none. As you can imagine, I'm hesitant to part with our 10k but wary it will take more weeks as it already took this long enough to get to this point. Is this the time to be 'fussy' or is there another construction set of drawings to sign-off. Thanks again. Im not exactly sure of this either. Wary of once you pay the 10k, then other changes are 1k a pop. But they have assured me more than once that changes resulting from your landscaping plan, cdc/da required changes, and interior selection, changes don't cost us to update plans. And obviously electricals too, we haven't got to that phase. But like you i would want to be 100% sure the plans are accurate before construction starts! I'm fully expecting my kitchen, laundry, butlers layout will change post those detailed design phases. i also want to change some door widths and shower types, havent even thougt about the 3 WIRs (use elba or do post handover), want to put a chute in - i was told that's in interior selection phases. Things like missing niches etc that were on tender plans but not proper plans now ive gotten put on. And anything clearly wrong, asked to be fixed. If i was you id insist on anything structural being in now, but not tile choices maybe. Not sure i know what a tiled hob is sorry lol to know if crucial to get in plans now or not (our dwarf walls on alfresco are in plans now if that helps). The only thing showing on my plans now is glazing and window upgrades, waterfalls, recessed flooring, ledges etc. Not other fixture and finishing selections i have. Like I have a flooring provision, but it still shows tiles on the plan...I guess as I haven't locked down that selection. It is frustrating that we turn plan comments around in 1-2 days and they take weeks. But so far they've been great to deal with so Im happy everything is nice and relaxed. But i thought I had the longest tender in the world, but now im actually wondering if i will make tender expiry date! Pre construction is generally frustrating. Our tender and getting ready for DA nearly made me have a melt down. Even after the council approval came we went a few months before we got to construction. If it helps construction phase is delightfully quick. So hang in there and tell them to give you updates of progress. What frustrated me was the utter silence when I didn’t know whether my project was moving along or not. The intent of the architectural plans you’re going to sign are for getting DA submission ready. So focus on all external and structural aspects very well. Walls, dwarf walls, external colour selections, setbacks, roof types, ceiling heights, courtyards, window location, window glazing, window sizes and window types, nominated location for rainwater tank, etc. You don’t want to backtrack on council plans at any cost. So focus on external, structural and anything impacting Basix ( if you’re doing solar through Hall and Hart get it in too) Tiling, carpets, WIR, electrical, kitchen And colours selection are internal and are only done once DA submissions are in progress. We even included few niches in bathrooms etc with no admin fee. If it gives you any comfort we had about 10 tender variations with many line items each to reflect changes on internal selections and finishes. No fee demanded whatsoever. Best wishes. Re: Building with Hall & Hart Homes 1012May 17, 2020 9:28 am [quote="msresearcher":1j7bbh21]Hi all Can I have some advice. Im in a loop of how to pick tiling before kitchen or vice versa. They seem to suggest tiling first, then kitchen later (towards end). I am unsure if I will go a standard included silestone bench top or upgraded (depends on upgrade cost!). My tiling choices for floor and splashbacks are completely different depending on which the 2 bench tops I go with for kitchen/laundry/butlers. Can you go back and change your selections if a later decision unwinds an earlier one? Or maybe I should just do kitchen design before tiling? Argh. Trying to get organized but I feel like too many decision points and I am unnecessarily mocking up two different pallets.[/quote:1j7bbh21] For purely practical reasons I did Tiling and Floor coverings through accent first. Used the samples to lock down Elba selections. Reason was Elba is a fair commute for us plus only gives you two hour appointment and doesn’t allow you browsing time in store. Only appointment based visits. You want to make most of that time. The colour schemes need to flow from the same colour palette. So you absolutely need a basis. For Beaumont we had the ability to go in and out of store looking through things many times before we were ready to make appointment for colour consultation and finalise. I’m glad I did it this way as I was favouring more browns than greys initially but noticed that Beaumont has more greys and neutrals (not browns). So if I’d done all my Elba selections only to find my tile colours did not exist I’d have been in trouble. Also not sure if Elba will give you a second appointment or that costs $$. I must add floorboards and carpets much easier as you’re spoilt for choice and not limited like tiles. Re: Building with Hall & Hart Homes 1013May 18, 2020 7:15 am I understand what you’re suggesting but doing it that way I have to either commit to massive upgrade now or just give up on my preferred bench now and pick the plain white one. I just wish they could tell us prices now so I could decide and move on. Re: Building with Hall & Hart Homes 1014May 18, 2020 7:16 am 2hr kitchen laundry bathroom wirs joinery sounds insane. I could barely do kitchen in 2 hrs. I want to fully consider all cabinetry options! Re: Building with Hall & Hart Homes 1015May 18, 2020 8:32 pm Hi again. What is standard drain in shower? Just wondering re floor tile size? Beaumonts tell me floor drain is relevant to that. Cheers Re: Building with Hall & Hart Homes 1016May 18, 2020 9:09 pm msresearcher Hi again. What is standard drain in shower? Just wondering re floor tile size? Beaumonts tell me floor drain is relevant to that. Cheers You can do the smart tile waste upgrade through Beaumont so they can handle it through your selections. You can also do it through Hall and Hart if you Want to and they will refer your selections and estimate the cost. Re: Building with Hall & Hart Homes 1017May 18, 2020 9:58 pm msresearcher 2hr kitchen laundry bathroom wirs joinery sounds insane. I could barely do kitchen in 2 hrs. I want to fully consider all cabinetry options! Another option for WIR is Stegbar which we organised during our Studio You appointment. We got quote from Elba but was very expensive. We chose Stegbar in the end for drawer/shelf combo in both kids rooms as well as our WIR. With regards to kitchen, we have done 40mm Caesarstone benchtop & waterfalls in upgraded Raw Concrete & Snow (outside range) on Cook Run. It was less than $1k. We went to Beaumont Tiles a few times before we had our appointment to get ideas of tile colours/layouts we liked. Elba started installing our kitchen today so cant wait to see it all come together. Re: Building with Hall & Hart Homes 1018May 18, 2020 10:11 pm Thanks Elysebuild, very helpful. I got the Stegbar brochure and assumed that was still Via Elba. Interesting to know that’s via studio you. I think my Concern with bench top is we are building the soho with Servery and butlers. So any upgraded stone will be island, Back kitchen bench, butlers bench, laundry, servery and outdoor kitchen. It’s all so close together I want it all the same. Plus we possibly wanted to upgrade the 3 bathroom benches. Re: Building with Hall & Hart Homes 1019May 18, 2020 10:13 pm [quote="SDS1":37zas1rr][quote="msresearcher":37zas1rr]Hi again. What is standard drain in shower? Just wondering re floor tile size? Beaumonts tell me floor drain is relevant to that. Cheers [/quote:37zas1rr]
You can do the smart tile waste upgrade through Beaumont so they can handle it through your selections. You can also do it through Hall and Hart if you Want to and they will refer your selections and estimate the cost.[/quote:37zas1rr] Thanks! Which is best (cheapest?) way to do it? If you don’t have smart tile waste, what is supplied? I was thinking like a linear waste or something would be the upgrade. Re: Building with Hall & Hart Homes 1020May 18, 2020 10:17 pm msresearcher SDS1 msresearcher Hi again. What is standard drain in shower? Just wondering re floor tile size? Beaumonts tell me floor drain is relevant to that. Cheers You can do the smart tile waste upgrade through Beaumont so they can handle it through your selections. You can also do it through Hall and Hart if you Want to and they will refer your selections and estimate the cost. Thanks! Which is best (cheapest?) way to do it? If you don’t have smart tile wast, what is supplied? My recollection was Beaumont was cheaper but maybe ask both and see what works. Standard is round Chrome floorwaste I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9052 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 77377 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 107921 |
