Browse Forums Building A New House Re: Building with Hall & Hart Homes 1094Sep 18, 2020 5:08 pm Amanda_Ly My advice would be to go in knowing exactly what you would like in your dream kitchen. I wrote down a list of what I need to store in my kitchen so I could determine how many/wide each drawer needed to be. I also visited the Caesarstone store so I could see large pieces of the stone and visualize the patterns. Once you choose the stone you can choose the colour cabinetry to match. Research what material you'd like the cabinetry to be. Polyurethane and Thermo-wrapped were in the same price bracket, both upgrades. If you are upgrading your kitchen appliances you'll also need to provide this to Elba. We are looking at upgrading our kitchen appliances but, HHH said they don't really get a discount on non standard appliances. Did you source your upgraded appliances and install after handover? Or did you get upgraded appliances through HHH? We need all new appliances (fridge, wachining machine, dryer). I'm thinking if we can include the oven x2 and cooktop (with a credit for HHH) we could get a better price sourcing ourselves and install post handover? Re: Building with Hall & Hart Homes 1095Sep 18, 2020 5:25 pm jo-t Will let Amanda respond to your specific question above. Budgeting for post handover instal remember that you may need trims and seals around the appliances etc. Check if your appliance supplier does that or you need to factor costs at your end for finishes. Re: Building with Hall & Hart Homes 1097Sep 18, 2020 9:40 pm We had handover of our Elyse 36 with Sienna Contemporary facade in early August & have been in almost a month. Slab was poured in mid December then Framework started mid January. Very happy with everything to do with H&H. We had one provision at Contract stage which was for rock excavation which ended up being credited at the end because there was none which we were thrilled about. We had very minimal changes after contract signed (less than $5k). We are really loving our home & we had an awesome Site Supervisor who was always available to answer any questions, big or small. He is still dropping by Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Hall & Hart Homes 1098Sep 19, 2020 10:24 pm Has anyone deleted the 3 in 1 heat/fan/light combos in the bathrooms? I'm on the fence as I haven't seen them in newer houses and I've never had them before. If you deleted them, how much credit did you get back? Thanks Re: Building with Hall & Hart Homes 1099Sep 20, 2020 5:53 pm They don't put them in bathrooms now as most en-suites (particularly master bedroom) are open to the room, so that any heating being used is basically being "leaked" into the ceiling space through the fan area. The stand alone exhaust fans these days are vented to outside (by law in Vic), and also have a valve to close off the vent when not used (to prevent heat loss mentioned above). It can't really be enclosed as it generates a lot of heat from the heat lamps. And they are available from Bunnings for only $173, so the amount back might only be a few hundred. But what will keep you warm in the winter mornings in the bathroom? It is also a good source of light for the ladies to do their makeup... Re: Building with Hall & Hart Homes 1100Sep 21, 2020 9:26 pm barnie22 Has anyone deleted the 3 in 1 heat/fan/light combos in the bathrooms? I'm on the fence as I haven't seen them in newer houses and I've never had them before. If you deleted them, how much credit did you get back? Thanks Hi, I did , about 2.2k for 3 x bath/ens including the ducting. I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8823 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74717 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105617 |
