Browse Forums Building A New House Re: List of Things You Can't Do Later 2Mar 01, 2017 8:10 am You can do home theatre wiring later... Simply put, anything structural can't be done/altered later or will be too costly.... the rest can be.... Re: List of Things You Can't Do Later 4Mar 01, 2017 8:38 am Example, wiring for the home theatre or security systems or decorative lights on facades: these are not structural. Is it still possible to do these after the construction - I mean without being costly and without being displeasing to our eyes (e.g. wires or PVC tubes running outside...) ? Re: List of Things You Can't Do Later 5Mar 01, 2017 5:11 pm Plumbing... e.g provisions for water to fridge cavity and gas and water to outdoor BBQ. I'd also consider anything in the walls to your ground floor as a must do as you will not get access after that second storey goes on! Of course, insulation is also a must consideration during build too. While I'm at it.. If you need access to your backyard to install a spa or pool you might want to do that during/before construction. Re: List of Things You Can't Do Later 6Mar 01, 2017 10:32 pm Off the top of my head - High ceilings, lighting for the ground floor if you aren't single level, plumbing, ducted air conditioning, sizes of rooms. Things like a hand basin in the WC. Re: List of Things You Can't Do Later 7Mar 02, 2017 6:01 am Thank-you RegVic, asha27, Special_K and yvonneh. This list would benefit all new builders who need to make some difficult choices sometimes between building something now and leaving it for later. Its a nice and handy list to have in one place. Here we go: List of Things You Can't Do Later (Either because its not possible structurally OR because of high costs OR because its not going to look nice)
It would be great if the experienced builders can double-check this list and offer any corrections or improvements where needed. Re: List of Things You Can't Do Later 9Mar 02, 2017 9:49 am - Double Glazing windows... - Change Weatherboards...... to bricks ( costly to paint every 7 to 10 years ) - Gas bayonet for upstairs living / lounge rooms - Weather proof power points....for outside - Check shower area....increase shower area by height and width ( for tall people ) Re: List of Things You Can't Do Later 10Mar 02, 2017 2:51 pm In re to weatherboard.. Modern construction doesn't use the old wooden weatherboards anymore. A lot of builders use a product called LINEA that is resistant to expansion and contraction in traditional weatherboards. Yes, you will still need to paint it over time but you would need to do that with render over brick or hebel as well. Re: List of Things You Can't Do Later 11Mar 03, 2017 7:11 am Thank you G1NOSAUR, shadow and Special_K, here is the updated list: List of Things You Can't Do Later (Either because its not possible structurally OR because of high costs OR because its not going to look nice)
I would recommend folks reading this list also read the contributors' thread as they have added more details and explanations and if necessary contact them as well directly for clarifications. Anything else to add to this lis!? Re: List of Things You Can't Do Later 12Mar 03, 2017 8:42 am I have one ... sort-of. It's something you can only do "in between". Getting a protective (and less fugly) epoxy coating applied to the garage floor! You don't pay the builder to do this, of course, but once you've actually moved in there's close to zero chance you can ever manage the logistics to get it done. So you somehow have to coordinate the people with the appropriate safety gear (the Bunnings stuff which you can apply without dying isn't good enough to last) to do it after handover but before you start moving your crap into the garage (and frankly - the garage is the first place you put something which you don't want to chuck but doesn't belong in any of your shiny new rooms). Re: List of Things You Can't Do Later 14Mar 03, 2017 11:00 am It's mostly for appearance. I don't like unfinished concrete inside at the best of times, but cars tend to drip various fluids which seep into the concrete & never come out, things like paint tins get dropped; and it's nicer if you can clean with a quick wipe (whereas if your car drips anything but water on unfinished concrete it seeps in & never comes out). The builder also tends to use the garage for a place to keep messy stuff while building, our garage has all sorts of ingrained circular rust marks where tins were rusting, there's some spilled bathroom sealant, splatters of paint etc. Now my garage is used for tinkering with cars, so it's even more useful to be able to wipe things off rather than having them soak in & stay forever. I've just used a plain light grey, easier to see dropped things & also stops the garage feeling too dark; but for a garage that you want to look a bit neater/cleaner than a car-tinkering shed like mine you can get all sorts of funky patterns in the coatings, such as: [url=[url=http://blogule.com/wp-content/uploads/2016/07/concrete-floor-coatings-polyaspartic-floor-coatings-advacoatc3a2c2ae-concrete-floor-coatings.jpg]]http://blogule.com/wp-content/uploads/2016/07/concrete-floor-coatings-polyaspartic-floor-coatings-advacoatc3a2c2ae-concrete-floor-coatings.jpg][/url]This[/url] Re: List of Things You Can't Do Later 15Mar 03, 2017 11:01 am Sorry I can't find how to edit the above ... dunno how this forum's links work ... let me try again: http://blogule.com/wp-content/uploads/2016/07/concrete-floor-coatings-polyaspartic-floor-coatings-advacoatc3a2c2ae-concrete-floor-coatings.jpg Re: List of Things You Can't Do Later 16Mar 03, 2017 12:42 pm Forg Sorry I can't find how to edit the above ... dunno how this forum's links work ... let me try again: http://blogule.com/wp-content/uploads/2016/07/concrete-floor-coatings-polyaspartic-floor-coatings-advacoatc3a2c2ae-concrete-floor-coatings.jpg Thanks Forg. Looks great but if it comes down to an upgraded to the kitchen of the garage floor, i know what my Mrs will want! Re: List of Things You Can't Do Later 19Mar 06, 2017 7:39 pm Forg Sorry I can't find how to edit the above ... dunno how this forum's links work ... let me try again: http://blogule.com/wp-content/uploads/2016/07/concrete-floor-coatings-polyaspartic-floor-coatings-advacoatc3a2c2ae-concrete-floor-coatings.jpg My husband did our garage floor after handover over 2 weekends. Looks amazing Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11766 2 11070 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20979 |
