Browse Forums Building A New House 1 Apr 11, 2016 4:39 pm Anyone building a house with front balcony over the garage? Is it allowed in New South Wales or just not all builders do it for water leaking issue? If proper waterproofing is done should it be a huge concern still? [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Balcony over the garage 2Apr 11, 2016 5:39 pm I think there may be waterproofing issues building a balcony over an enclosed section of the lower storey. I could be wrong but I feel like I remember having that conversation with a builder M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Balcony over the garage 3Apr 12, 2016 12:57 am We are. Our balcony sits over the garage with eaves from the edge of the balcony over the front of the garage. Guessing that resolves any water issues.... maybe?? Re: Balcony over the garage 4Apr 12, 2016 1:15 pm You can build a balcony over a garage or even living space, but it does complicate the waterproofing, and increases the risk of greater damage if there is leakage. So expect greater costs, and you want to have good trust in your builder doing the job right. If there's roof cover over the balcony and eaves overhang it would reduce the risk a bit, but you can still get wind-driven rain I think there are also aesthetic reasons why builders tend not to have designs with balconies above built-in areas. Re: Balcony over the garage 5Apr 12, 2016 1:45 pm The other issue is structural. A double garage will mean large unsupported spans and large pre-cambered steel beams will be required. In addition a balcony is designed for a live load of 4kPa whereas a room inside a house is designed for a live load of 2.5kPa (I think) Good morning, Thinking of using a PVC product for our balcony ceilings which are expected to have high exsposure to salt spray from the ocean. Has anyone here used PCV… 0 32874 Hello all I have a 13-year old first-floor balcony deck, and three of the posts supporting the balustrade are coming apart right down the middle. (I am attaching two pics,… 0 24667 Building Standards; Getting It Right! AI responses such as these are typically unhelpful so do with it as you wish. Especially important to consider is those responses closing with “I recommend consulting… 2 62180 |
