Browse Forums Building A New House Re: KDR with Sekisui house 761Sep 06, 2016 9:11 am Building a sekisui house in Holmesville NSW viewtopic.php?f=31&t=75060 Re: KDR with Sekisui house 762Sep 06, 2016 12:42 pm I loooove the floor boards, are they bamboo? What's the colour? Re: KDR with Sekisui house 763Sep 06, 2016 6:34 pm EPaul888 I loooove the floor boards, are they bamboo? What's the colour? Laminated board. can't remember what it is called. Went to warehouse and chose. 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui house 764Sep 06, 2016 7:25 pm Looks fabulous. Nice flooring choice. And better decision to have it installed before handover! Re: KDR with Sekisui house 765Sep 08, 2016 9:03 am Handover done but no certificate yet. 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui house 767Sep 08, 2016 9:31 am Building a sekisui house in Holmesville NSW viewtopic.php?f=31&t=75060 Re: KDR with Sekisui house 768Sep 09, 2016 4:37 pm Telecom issues if anyone can help. Optus came in to lay cable and the only thing they could do was to terminate cable in garage and install modem in garage. SH has instructed the electrician to do NBN only. Second issue, since we only get cable to coax we get ip based phone number. When phone connected to modem there is no signal to the ports inside the house, Optus technician thinks that there is no connection from garage to the other rooms for phone,its data only. Not happy, not sure what to do.. I'll talk to SH though. 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui house 769Sep 09, 2016 6:20 pm Congrats on keys!! If you have phone ports and data ports they should be wired in. Re: KDR with Sekisui house 770Sep 10, 2016 8:31 pm vivmak Telecom issues if anyone can help. Optus came in to lay cable and the only thing they could do was to terminate cable in garage and install modem in garage. SH has instructed the electrician to do NBN only. Second issue, since we only get cable to coax we get ip based phone number. When phone connected to modem there is no signal to the ports inside the house, Optus technician thinks that there is no connection from garage to the other rooms for phone,its data only. Not happy, not sure what to do.. I'll talk to SH though. Hi Vivmak I asked someone who knows a thing or two about nbn and Optus, below is what he told me. “Firstly, on nbn, you can check whether nbn service is available for your home by entering your address in their website http://www.nbnco.com.au/connect-home-or-business/information-for-home.html . Optus or any other major service providers can also let you know that whether nbn service is available for your address or not. Sounds like you don’t have nbn coverage yet, but worthwhile checking. Secondly, I am not sure while Optus had to install the modem in Garage (if that was not your choice of location). Sounds like Optus is installing new HFC (Hybrid Fibre Coaxial) service for you by bring coaxial cable from the street to your house. They could have terminated somewhere inside the house as long as there is power point nearby. Did he give you the reason? The only reason I could think of (why he installed the modem in the garage) is if he brought the coaxial cable to the house using SH preinstalled conduit which terminated in the garage and he got no easy way of extending that coaxial cable from garage to further into the house. If that the case and if you have SH wired phone and data lines from garage to rooms inside, it will still work. You keep the modem stays inside the garage, then connect the phone port on the modem to the phone lines going into the house (same for data port on modem to data line going into the house). Regarding the ip based phone, it is nothing wrong having ip based phone but it needs to be working of course J. If you connect your phone directly to the modem phone port, does it work? If it does work there and not inside the house, it is clearly wiring problem (between garage and phone port inside the house). If the phone doesn’t work even at the modem phone port, it might be the problem within Optus (not inhome wiring). Personally, I would prefer to have the modem inside the house, it is much easier for WiFi and cordless phone coverage as well. Note that nbn doesn’t have such a rule that you must keep your modem (or Network Terminating Device, NTD) in the garage. “ Hope this help! Good Luck with Optus and SH. viewtopic.php?=31&t=81624 Re: KDR with Sekisui house 771Sep 14, 2016 8:53 pm Thanks for response and info. Garage to ports inside the housr are not working it seems. Tried connecting phone point from the modem and no dial tone inside the house. Might need to call electricians. Basically modem to rj 6e jack in garage and then tested from port inside the house. Didn't work. 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui house 772Sep 28, 2016 12:30 pm Is your Telecom issues sorted out ? Your tiles complete for ground floor area ? viewtopic.php?f=31&t=81624 Re: KDR with Sekisui house 773Sep 29, 2016 10:49 pm Telecom issue isnt sorted. I need to still contact electrician. For now i am living with low speed wifi to the end rooms. Floors done. Drive way still to be done. 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui house 774Sep 29, 2016 10:51 pm Not sure if i have posted these or not but here is ground floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui house 775Sep 30, 2016 12:47 am Very nice floor. Your tiles are very large and it's gives a neat clean look. The size of your tiles ? viewtopic.php?f=31&t=81624 Re: KDR with Sekisui house 776Sep 30, 2016 8:26 am Wow look at those tiles.. they are amazing. sekisui build viewtopic.php?f=31&t=75060&p=1573965#p1573965 Building a sekisui house in Holmesville NSW viewtopic.php?f=31&t=75060 Re: KDR with Sekisui house 777Sep 30, 2016 3:35 pm shazaw Very nice floor. Your tiles are very large and it's gives a neat clean look. The size of your tiles ? viewtopic.php?f=31&t=81624 600x1200 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: KDR with Sekisui house 779Sep 30, 2016 9:35 pm Wow amazing tiles! The colour blends perfectly to your wall colour! Re: KDR with Sekisui house 780Sep 30, 2016 9:38 pm cat_dunc Those tiles are epic! So gorgeous. I'm imagining it with furniture and rugs and cushions and paintings. Its going to be stunning Now that is a challenge, plwase share your imagination 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37150 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19108 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13447 |
