Browse Forums Building A New House 1 May 04, 2014 9:02 pm Hi all To everyone having a colorbond roof. Are you installing sarking to your roof line? Is it an additional cost? If so, what was the cost? Is it better to have it included in your build or do it after handover? Cheers BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Sarking through builder 2May 05, 2014 7:56 am We had sarking installed under our tiled roof, I think it was about a $1000 upgrade. I don't think you can get it done after. Not sure if there are benefits to having it with colorbond roof. Re: Sarking through builder 3May 05, 2014 8:23 am We changed to a cb roof and had our sarking changed by the builder to an anticon blanket... We assume that's the recommend approach. Re: Sarking through builder 4May 05, 2014 8:29 am yvonneh We changed to a cb roof and had our sarking changed by the builder to an anticon blanket... We assume that's the recommend approach. Thanks yvonneh. Do you know why an anticon blanket was used over sarking? Shambini BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Sarking through builder 5May 05, 2014 8:31 am Anti con means anti condensation. Assume it does the job of sarking as well... It's a Bradford product if you want to do a quick Google Re: Sarking through builder 6May 05, 2014 11:33 am Sarking would be a really high recommendation from me to get underneath a Colorbond roof. Sarking is essentially reflective foil, which is great under Colorbond, as it will help reflect the heat away from your roof, giving you better insulation performance. It will also help draught and moisture from the roof going past the sarking. While an anitcon blanket is the more preferred option for metal roofs. Not only does it give better insulation value and condensation control, but the added benefit of noise reduction, as metal is not a quiet thing when it rains/hails/storms. Building Standards; Getting It Right! Hi all Iām in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 13756 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7382 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38521 |
