Browse Forums Building A New House Re: Site works - what does this involve 2Jun 04, 2010 10:26 pm Its a definition which probably differs between builders however some of the things that I class as site costs are: * Site cut and fill (to level the block where the house will be sited) * Slab upgrades based upon soil type on the block * Piering or piles that may be required under the slab due to fill or easments etc.etc. * Retaining walls Other things not technically sites costs but can be required for the site to not forget about * Temporary fencing * All weather access to a block * Additonal drains (ie. if your house will be lower than road level, additonal drain will be required for a future driveway drain) There is more that others can fill in! Re: Site works - what does this involve 4Jun 04, 2010 11:04 pm Thanks for that will0305 and Sierra ... we are in Perth and have been told that our inner-city block 10m x 50m block site works will be around 15K - even though it is though to be a "good" block?? This is a provisional sum only but does seem excessive to us... do you know if it is common to get independent site works done?? Re: Site works - what does this involve 5Jun 04, 2010 11:09 pm Here's a list of what our builder (Coral) has included in the site costs... Site cut and fill Site classification (slab) and concrete pump Power, sewerage, stormwater and water supply onsite managament (things like fencing, portaloos, OH&S requirements etc) Council fees, BASIX (NSW), and bushfire requirements were seperate charges. Retaining walls and tree removal are classed as 'by owner' items, so we had to arrange those on our own. Hope that helps Nic. Built the Coral Homes Hamilton 252 - moved in 20/10/2010 and loving it!! https://forum.homeone.com.au/viewtopic.php?t=27215 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7128 MBA and HIA both have sub contract agreements, check them out 2 7317 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4814 |
