Browse Forums Building A New House 1 Aug 13, 2025 5:18 pm Hi There, Along with building new house, I am thinking to add upgrade to build concrete elevated balcony. The 2 sides of balconey will be fixed onto the exsiting walls. Size is about 20 sqm. No cover is needed. It is off the ground for 2~3m Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ To save the cost , I am thinking of skipping floor finish ( just keep the raw concrete finish ) and do the balustrade later. Does anyone have similar experience or know how much this will cost me ? Re: Cost of building concrete elevated balcony 2Aug 15, 2025 8:43 am Has the house started to be built yet, or do you only have plans so far? Is the house built the same way, ie. with concrete flooring? If the house isn't built the same way, what is the reason for wanting concrete on just the balcony? Re: Cost of building concrete elevated balcony 3Aug 18, 2025 12:29 pm No yet. the balcony is elevated one. the space under it will be empty. But the concrete base of main house will be fully filled. Good morning, Thinking of using a PVC product for our balcony ceilings which are expected to have high exsposure to salt spray from the ocean. Has anyone here used PCV… 0 32874 Hello all I have a 13-year old first-floor balcony deck, and three of the posts supporting the balustrade are coming apart right down the middle. (I am attaching two pics,… 0 24667 Building Standards; Getting It Right! AI responses such as these are typically unhelpful so do with it as you wish. Especially important to consider is those responses closing with “I recommend consulting… 2 62181 |
