The island is 2632 and the under window bench is around 3310.
Browse Forums Building A New House Re: Metricon Winchester 28- Home Straight 841Aug 17, 2018 8:32 am Bronte19 The white paint looks really good. What's the length of your kitchen bench and island? The island is 2632 and the under window bench is around 3310. Re: Metricon Winchester 28- Home Straight 842Aug 17, 2018 8:36 am blackcat20 Kimmykim That window splashback is stealing the spotlight! PCI next month so it only takes 4 months for the build?! That pace is unbelievable! Ours was very fast too. We had out frame and slab done within 10 days. It went so fast till near the end. When the suppliers for the balcony and splashback held us up. viewtopic.php?t=86597 Re: Metricon Winchester 28- Home Straight 843Aug 17, 2018 8:40 am Doulton777 blackcat20 I know! We officially started May 9 Ours was very fast too. We had out frame and slab done within 10 days. It went so fast till near the end. When the suppliers for the balcony and splashback held us up. viewtopic.php?t=86597 I'm astounded how fast and smoothly its run so far. We dont have a lot of tiling so assume that wont take too long. Garage door has been measured, as have fly screens. Inside needs sinks, taps etc, then electrical and door handles. Saw the box for our range hood on site. Then flooring needs to be done. Outside we still need the eaves for the garage front, then the ceiling of the portico and alfresco needs painting. Then site clean and driveway and front path. Re: Metricon Winchester 28- Home Straight 844Aug 17, 2018 1:51 pm Re: Metricon Winchester 28- Home Straight 845Aug 17, 2018 4:57 pm blackcat20 Just over a week for the painting. When we went last Friday they had finished the ceilings and done one coat in the walls. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Metricon Winchester 28- Home Straight 846Aug 17, 2018 5:00 pm When they cleaned our bricks, we noticed the flaws with the mortar....like holes in some areas or gaps, different coloured mortar on a full wall.....the new SM said they will be fixing that in the next week. The Brick company probably came too early to do their QA or check. https://r.tapatalk.com/shareLink?url=ht ... are_type=t Re: Metricon Winchester 28- Home Straight 847Aug 17, 2018 5:24 pm blackcat20 Bronte19 The white paint looks really good. What's the length of your kitchen bench and island? The island is 2632 and the under window bench is around 3310. That's great. Your bench is good length. Re: Metricon Winchester 28- Home Straight 848Aug 17, 2018 10:32 pm excited_builders When they cleaned our bricks, we noticed the flaws with the mortar....like holes in some areas or gaps, different coloured mortar on a full wall.....the new SM said they will be fixing that in the next week. The Brick company probably came too early to do their QA or check. https://r.tapatalk.com/shareLink?url=ht ... are_type=t The mortar getting washed out is pretty normal, we've got quite a lot like that, they'll patch it up and you won't even know the difference Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Home Straight 850Aug 18, 2018 7:52 pm MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. Re: Metricon Winchester 28- Home Straight 851Aug 18, 2018 7:56 pm blackcat20 MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. They should have temporary plastic down pipe to direct water away during construction stage. Re: Metricon Winchester 28- Home Straight 852Aug 18, 2018 8:00 pm MyFirst blackcat20 MyFirst I thought expose down pipe where water just run down the brick wall and then to the slab Isn't that a big no no? Definitely a big no no. Once the bricks have been cleaned they'll attach th remainder of the down pipe and connect it. They should have temporary plastic down pipe to direct water away during construction stage. Re: Metricon Winchester 28- Home Straight 853Aug 20, 2018 9:02 am Re: Metricon Winchester 28- Home Straight 855Aug 20, 2018 9:21 am I found getting a response from fencing contractors like playing Russian Roulette... I rang 11, and 2 got back to me... End up with the third quote from a guy who travels down from South Seymour via word of mouth, and he was the cheapest quote... Go figure Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Metricon Winchester 28- Home Straight 856Aug 20, 2018 9:27 am I went with Endless fencing. The price was very reasonable for two side fences and a merbau gate. Their work looks good too. Re: Metricon Winchester 28- Home Straight 857Aug 20, 2018 10:04 am Drew01 I found getting a response from fencing contractors like playing Russian Roulette... I rang 11, and 2 got back to me... End up with the third quote from a guy who travels down from South Seymour via word of mouth, and he was the cheapest quote... Go figure I have that problem at well. Rang many but only 2 called back. 😓 Re: Metricon Winchester 28- Home Straight 859Aug 20, 2018 10:07 am Looks promising! So near to finishing line! Do you have any idea how long will be from PCI to handover? Re: Metricon Winchester 28- Home Straight 860Aug 20, 2018 10:14 am Kimmykim Looks promising! So near to finishing line! Do you have any idea how long will be from PCI to handover? Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36570 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 14366 Yes, I was happy with the work, bar a few small things. Overall, communication could have been better though. However, I found them reliable and did good work at a… 4 63062 |
