Browse Forums Building A New House Re: Building with Ventura, Baldivis - PLASTERING.... ! 81Nov 28, 2013 1:09 pm Some friends are building in Madora Bay with Cont3nt Living and have just asked for the shower head to be raised.........................checked ours and they are at 1850mm which is pretty much my height so will have to ask for ours to be raised too ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - PLASTERING.... ! 82Nov 28, 2013 3:12 pm chardy Some friends are building in Madora Bay with Cont3nt Living and have just asked for the shower head to be raised.........................checked ours and they are at 1850mm which is pretty much my height so will have to ask for ours to be raised too ! I am hoping ours will be high enough then! My hubby is 190cm so will need to be tall enough to fit him under. Do you have 2mtr tall screen and tiling? RHI - BALDIVIS PERTH 2005 Bought/Finished WA Housing Centre Home 2010 Building the Benchmark with REDINK Homes in The Avalon 2013 Building the Michigan with Cont3nt Living In Highbury Estate! Re: Building with Ventura, Baldivis - PLASTERING.... ! 83Nov 28, 2013 3:13 pm We got our point at 2m and then the arm of shower points up making it even taller Re: Building with Ventura, Baldivis - PLASTERING.... ! 84Nov 28, 2013 3:36 pm We have full height tiling in the ensuite and the Caroma Quatro head seems to be at least 90mm above the outlet with further lift available so should be ok. However we will have to revert back to the rail type in the main bathroom as our 4 year old has started showering but only if she holds the head !! Sent from my iPhone using Tapatalk Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - PLASTERING.... ! 85Nov 28, 2013 3:39 pm Not only are we neighbours but I have a 4yr girl too!!!! and also a 6yo Boy RHI - BALDIVIS PERTH 2005 Bought/Finished WA Housing Centre Home 2010 Building the Benchmark with REDINK Homes in The Avalon 2013 Building the Michigan with Cont3nt Living In Highbury Estate! Building with Ventura, Baldivis - PLASTERING.... ! 86Nov 28, 2013 5:19 pm rhi3384 Not only are we neighbours but I have a 4yr girl too!!!! and also a 6yo Boy That's great to make a new friend for our Grace although our boy is 8 and have another girl of 10. Just rung the CLO and to revert back is a variation plus labour and extra material cost so probably about $750. I guess we'll change it after handover then ! Sent from my iPhone using Tapatalk Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - PLASTERING.... ! 87Nov 28, 2013 9:01 pm Oh that's brilliant! Not so good about the cost though I always get annoyed how they can charge such a large variation cost! RHI - BALDIVIS PERTH 2005 Bought/Finished WA Housing Centre Home 2010 Building the Benchmark with REDINK Homes in The Avalon 2013 Building the Michigan with Cont3nt Living In Highbury Estate! Building with Ventura, Baldivis - PLASTERING.... ! 88Nov 29, 2013 9:41 pm Well our grey float is all done inside and the front/back render is double coated ready to paint I think. Hopefully ceilings start next week then the white coat and coving, fingers crossed for lock up before the Christmas break. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sent from my iPhone using Tapatalk Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Building with Ventura, Baldivis - PLASTERING.... ! 89Dec 02, 2013 3:12 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ NBN wiring went in today, have to wait and see if we can actually get it before the government changes the rules ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - PLASTERING.... ! 90Dec 05, 2013 3:17 pm Plasterboard delivery yesterday as well as the cavity slider frames built in for the activity room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Activity room cavity slider frames Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Two rolls of roof insulation............hope there's more to come !! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lots of plasterboard ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - PLASTERING.... ! 91Dec 08, 2013 6:10 pm Looked in on Thursday at about 4:30pm and three Chinese guys were just finishing. They've put up the ceilings and coving ALL through the house.......amazing !!! Sent from my iPhone using Tapatalk Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - PLASTERING.... ! 92Dec 11, 2013 3:55 pm House glazed yesterday and hot water solar panels fitted. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sent from my iPhone using Tapatalk Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - almost lockup??! 93Jan 13, 2014 10:08 am Drove by this morning and finally the white set plastering has started. Sanitary ware fitting should also start tomorrow as we need to deliver the ensuite bath for them to fit. Sent from my iPhone using Tapatalk Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - almost lockup??! 94Jan 17, 2014 3:22 pm chardy Drove by this morning and finally the white set plastering has started. Sanitary ware fitting should also start tomorrow as we need to deliver the ensuite bath for them to fit. Sent from my iPhone using Tapatalk Bath delivery now on Wednesday as the spout has only just been moved to the side wall. The fridge water supply drop has finally appeared as has the conduit for the aircon controller so at least the white set can be completed. Got the plans from the air con installers, we are having 10 outlets over 7 zones: 1. Kitchen/living/dining 2. Master Bed 3. Beds 2/3 4. Bed 4 5. Media 6. Study 7. Activity I have ordered NBN but put it on hold until we have a completion date - will be getting a 50/20Mbps service with 500Gb downloads and 2 months free for $79.95 a month on a 12 month contract, I'll use my previous Telstra modem/router as compatible. All from Activ8me.net.au Will let you know what it's like once we are in ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - almost lockup??! 96Jan 22, 2014 2:08 pm Front door and smaller internal doors hung yesterday together with the shelving in the robes started. Dropped off our ensuite spa bath today and the plumber already has the main bath on a concrete bed, cabinetry should be on site tomorrow SS thinks we should be ready for handover first week of March ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - almost lockup??! 97Feb 18, 2014 9:41 pm Glad to see someone else building with Ventura! Look forward to following your build Providence Estate - Wellard, WA - Ventura https://forum.homeone.com.au/viewtopic.php?f=31&t=68532 Pinterest (all selections): http://www.pinterest.com/aimees88/final-house-selections/ Re: Building with Ventura, Baldivis - nearly there ! 98Feb 27, 2014 2:11 pm About time I posted more pics ! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Before the benchtops... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My garage, love having a proper ceiling, not a board jointed one! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ensuite before tiling. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ensuite tiling Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bathroom tiling complete Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Building with Ventura, Baldivis - nearly there ! 99Feb 27, 2014 2:39 pm Nice feature tile in the ensuite Re: Building with Ventura, Baldivis - nearly there ! 100Mar 02, 2014 4:57 pm Love the bathroom tiling! We chose black for our ensuite so it's nice to see someone else choose dark Providence Estate - Wellard, WA - Ventura https://forum.homeone.com.au/viewtopic.php?f=31&t=68532 Pinterest (all selections): http://www.pinterest.com/aimees88/final-house-selections/ Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11798 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 21564 |
