Browse Forums Building A New House Re: Building at Bardia - New Breeze 622Mar 28, 2018 8:21 am absep19 Hi Folks, Assuming many are at same stage for April rego. and I am trying to get ducks in order, I have 2 questions to ask. You may be in same boat or from past experience you may have some recommendations... 1. My builder Rawson asked me for a landscaping plan before they go to council. I understand this to be done after registration but it make sense to get the company finalised. Did anyone have any recommendations on which company/group/landscaper can provide that and how much did they quote you for it? 2. I have flexibility to get my bush fire report outside of my builder. Rawson told me it would be couple of hundred of dollars without exact amount until yet. An outside vendor quoted $330 for CDC and $660 for DA. I am going through council,so 660 is my benchmark at the moment. Does anyone has any other vendor that I can touch base with and if you know how much they cost? Ask me your questions and I will be able to answer some of them as well. BTW, I have got second email from Dahua stating my lot will go in for mid April for rego, along with few other onwners in the list. Who else has got it? Regards Bas I got the email too, its a bit strange that they put all the email addresses on the email. Re: Building at Bardia - New Breeze 623Mar 28, 2018 9:46 am dolphin33 absep19 Hi Folks, Assuming many are at same stage for April rego. and I am trying to get ducks in order, I have 2 questions to ask. You may be in same boat or from past experience you may have some recommendations... 1. My builder Rawson asked me for a landscaping plan before they go to council. I understand this to be done after registration but it make sense to get the company finalised. Did anyone have any recommendations on which company/group/landscaper can provide that and how much did they quote you for it? 2. I have flexibility to get my bush fire report outside of my builder. Rawson told me it would be couple of hundred of dollars without exact amount until yet. An outside vendor quoted $330 for CDC and $660 for DA. I am going through council,so 660 is my benchmark at the moment. Does anyone has any other vendor that I can touch base with and if you know how much they cost? Ask me your questions and I will be able to answer some of them as well. BTW, I have got second email from Dahua stating my lot will go in for mid April for rego, along with few other onwners in the list. Who else has got it? Regards Bas I got the email too, its a bit strange that they put all the email addresses on the email. I know. whats your block number? I think one closer to school are going up first Re: Building at Bardia - New Breeze 624Mar 28, 2018 9:58 am Icthys99 absep19 Icthys99 Hi Bas Unfortunately, I can't answer your questions as my land's rego is so far away and I am at step 0 of the whole process. But you did offer to answer questions, so can you advise why you are going through council? Is it because your home size exceeds the prima facie floor area limits? Hi Icthys99, I evaluated CDC option. but with the setbacks, I cannot build the size of house and plan I wanted. So I chose Council and this might still be possible. Only downside is the council time to approve, but given that I am going to live there, I want to maximise and ready to wait few more weeks. CDC is pretty straight forward, but with council you have few option to play around things. I wasn't able to get PPOS as directed it endmondson DCP under CDC and so I had to compromise on the length of house to achieve that. With DCP, my front setback is only 3m, and it worked out. Once you have design in mind, speak with you builder where you will have to compromise minimum. However if everything works out design wise for you, I will recommend CDC. You will have ball rolling much faster. Hi Bas I am fine to go through council because I am looking to build a home which will exceed base CDC and DCP requirements. As you say, for something to live in, I don't mind the wait. So is your home size much bigger than the standard rules? Some builders are telling me I can fit a much larger home (like 20% more than allowed), but still within set backs and site coverage per the rules) and that this will pass through council. Should I be trusting the builders when they say this? Hi, No my home size is within the limits defined by council. However if I used CDC, their setback limits would have made it even smaller. So I chose council option to achieve max am allowed to build. I met about 15 odd builders and none told me we can go 20% above the allowed limit. All started discussion with what max I can do as per Edmondson DCP and then started to look at design that will fit my block. In fact Rawson started with 30 sq home and then brought it down to 27 because that's max I can do as per guidelines. Like I said before if I were to use CDC I wouldn't have even got 27sq. due to setbacks laid by CDC. I am disadvantaged with a 10m wide block and hence I can do max with zero lot building, but I loose windows on that side. However Rawson was excellent in designing in a way that it wont have any dark space. I spent more on larger windows where I can to get max light as well. PM me and I will share pic of my plan. Cheers, Bas Re: Building at Bardia - New Breeze 625Mar 28, 2018 10:03 am IamSAM The pier allowance for my lot was 65 lineal mt. and the actual turned up under 60. I think the piers were under a mt...however I did not attend the site so don't know for sure. The soil report (LOT Classification report) showed sample drills and the rock was within a mt. Hi Sam, Thanks for the info. Thankfully I have allowance for 100 liner mt. What we do not know as practice, how deep new breeze do sewer pegouts. The deeper, the more costly its going to be and builder can only know this when they do soil test after rego and from sewer diagram of new breeze. I was curious to find that out before hand. How it works is as much deep sewer line is that much is taken and as radius left around it and you can't build around that area. In my case, sewer is about 2.5m from my garage wall(rear lane access garage). So if its deep enough, I would have to shift garage or reduce its size . Re: Building at Bardia - New Breeze 626Mar 28, 2018 10:18 am Icthys99 I have a query regarding how early a builder should be chosen: My land won't register till around early-mid next year. Should I be looking at builders now? A lot of them say that putting a small deposit and maybe another extension fee will enable me to keep the current prices and promotions. They say doing this hedges against future price rises which may be well in excess of my initial outlay. Is this accurate? Should I just wait till closer to registration (say around Aug/Sep this year) to commence the process of signing on with a builder? My logic for finding someone early, such as now, would be to indeed secure current pricing and promotions, thereby avoiding price rises. This will also allow plenty of time to carefully select upgrades, make appropriate changes, and time to peruse the contract with a fine comb and check it against the previously agreed changes. Is this a wise course of action or is it better to wait? Also, how much should I trust the product review website in respect of the builders' ratings? They seem genuine but a lot of the project builders have horrible ratings, with the exception of a handful (but they happen to builders whose designs I am not fond of). How do I go about choosing a trustworthy builder? Sorry for so many questions but as this is my first time building, I am trying to gather as much information as I can. Obviously asking builders a lot of these questions will result in biased answers. Therefore, I thought to open up to fellow consumers who also don't want to be rorted of their hard-earned. Thanks. Hi Icthys99, My recommendation is leverage from other's experiences here. Some of the builders guys using here are Metricon, Rawson, Blue tounge,eden brae etc.
Hope this helps. Happy searching! Regards Bas Re: Building at Bardia - New Breeze 627Mar 28, 2018 10:32 am absep19 Icthys99 I have a query regarding how early a builder should be chosen: My land won't register till around early-mid next year. Should I be looking at builders now? A lot of them say that putting a small deposit and maybe another extension fee will enable me to keep the current prices and promotions. They say doing this hedges against future price rises which may be well in excess of my initial outlay. Is this accurate? Should I just wait till closer to registration (say around Aug/Sep this year) to commence the process of signing on with a builder? My logic for finding someone early, such as now, would be to indeed secure current pricing and promotions, thereby avoiding price rises. This will also allow plenty of time to carefully select upgrades, make appropriate changes, and time to peruse the contract with a fine comb and check it against the previously agreed changes. Is this a wise course of action or is it better to wait? Also, how much should I trust the product review website in respect of the builders' ratings? They seem genuine but a lot of the project builders have horrible ratings, with the exception of a handful (but they happen to builders whose designs I am not fond of). How do I go about choosing a trustworthy builder? Sorry for so many questions but as this is my first time building, I am trying to gather as much information as I can. Obviously asking builders a lot of these questions will result in biased answers. Therefore, I thought to open up to fellow consumers who also don't want to be rorted of their hard-earned. Thanks. Hi Icthys99, My recommendation is leverage from other's experiences here. Some of the builders guys using here are Metricon, Rawson, Blue tounge,eden brae etc.
Hope this helps. Happy searching! Regards Bas +1, my sales rep is awesome, he suggested few improvements (ie, north aspect window is important) on top of my modifications. Re: Building at Bardia - New Breeze 628Mar 28, 2018 10:50 am absep19 IamSAM The pier allowance for my lot was 65 lineal mt. and the actual turned up under 60. I think the piers were under a mt...however I did not attend the site so don't know for sure. The soil report (LOT Classification report) showed sample drills and the rock was within a mt. Hi Sam, Thanks for the info. Thankfully I have allowance for 100 liner mt. What we do not know as practice, how deep new breeze do sewer pegouts. The deeper, the more costly its going to be and builder can only know this when they do soil test after rego and from sewer diagram of new breeze. I was curious to find that out before hand. How it works is as much deep sewer line is that much is taken and as radius left around it and you can't build around that area. In my case, sewer is about 2.5m from my garage wall(rear lane access garage). So if its deep enough, I would have to shift garage or reduce its size . Hi, I have sewer lines along 2 sides and 2 manholes in my lot. There was no issue with that at all. So I think the new breeze sewer pegouts should not be an issue. Around settlement time, New Breeze will give you the Sewer Diagrams made by SYDNEY WATER. My pdf file is 6 pages so cannot upload as image here. I think this sewer diagram has detailed specs of the pipes. Re: Building at Bardia - New Breeze 629Mar 28, 2018 11:04 am IamSAM absep19 IamSAM The pier allowance for my lot was 65 lineal mt. and the actual turned up under 60. I think the piers were under a mt...however I did not attend the site so don't know for sure. The soil report (LOT Classification report) showed sample drills and the rock was within a mt. Hi Sam, Thanks for the info. Thankfully I have allowance for 100 liner mt. What we do not know as practice, how deep new breeze do sewer pegouts. The deeper, the more costly its going to be and builder can only know this when they do soil test after rego and from sewer diagram of new breeze. I was curious to find that out before hand. How it works is as much deep sewer line is that much is taken and as radius left around it and you can't build around that area. In my case, sewer is about 2.5m from my garage wall(rear lane access garage). So if its deep enough, I would have to shift garage or reduce its size . Hi, I have sewer lines along 2 sides and 2 manholes in my lot. There was no issue with that at all. So I think the new breeze sewer pegouts should not be an issue. Around settlement time, New Breeze will give you the Sewer Diagrams made by SYDNEY WATER. My pdf file is 6 pages so cannot upload as image here. I think this sewer diagram has detailed specs of the pipes. That's a relief. Thanks Sam. Re: Building at Bardia - New Breeze 630Mar 29, 2018 6:34 am Tolgz Whats your question hasan? just wondering how long the registration/settlement delay is from the original date you were told when purchased the land. I purchased the land on Bruce Ferguson (the part that is still closed) in mid 2017 and was told mid 2018 will be ready. But I don’t see that as accurate. I Would like to know from previous buyers who have already settled for there knowledge of the delay thanks Re: Building at Bardia - New Breeze 633Mar 29, 2018 11:03 am Hi everyone, Thought I'd share some information about building a house that's more than the allowed site coverage. I just got off the phone with a member of the planning dept at Campbelltown Council and was advised that they have and do allow variations so long as other building guidelines are met and your reasons for requesting the variation is justified. So wanting to utilise your land wont suffice - its got to be something like you run a business from home or you are caring for family members etc. In my case, both my parents and in laws will be moving in with us, so I'm hoping that will help our application. It's still not guaranteed but there's a good chance. Hope this helps! Re: Building at Bardia - New Breeze 635Mar 31, 2018 5:07 pm Hi all I'm new to this forum. I'm building in Bardia New Breeze on a 300sqm block. Just wanted to know what the setback boundaries are for the front, back and side of the property. I'm on a zero lot block for one side of my land. I'm most interested in the side setbacks as that seems to be my biggest issue with finding a design that will fit and have the rooms that I want! Thanks! Building in New Breeze, Stage 3 Parkside Bardia Re: Building at Bardia - New Breeze 636Mar 31, 2018 10:21 pm NZ89 Hi all I'm new to this forum. I'm building in Bardia New Breeze on a 300sqm block. Just wanted to know what the setback boundaries are for the front, back and side of the property. I'm on a zero lot block for one side of my land. I'm most interested in the side setbacks as that seems to be my biggest issue with finding a design that will fit and have the rooms that I want! Thanks! Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 637Apr 02, 2018 8:39 pm wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside Building in New Breeze, Stage 3 Parkside Bardia Re: Building at Bardia - New Breeze 638Apr 02, 2018 11:09 pm NZ89 wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside Hi NZ89, Have you check it with other builder ? Please double check with the builder and ask why you need 1.5m on the side. If not mistaken, you DO need 1.5m if you have a water tank on the side. But, why not move the water tank behind the garage ? (ie. close the garage door access to the garden, you dont need it do you ?) check it with the builder, If you dont have water tank on the side, do you still need 1.5m or 900mm ? Hope this info helps. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 639Apr 02, 2018 11:12 pm NZ89 wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside btw, I am on the lot 5 series, the very early first stage. behind the sales office and its about to be registered next 2 weeks. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 640Apr 02, 2018 11:24 pm wentworth33 NZ89 wentworth33 Hi NZ89, You will need to talk to your builder in regards of the setback. Setbacks are defined according to the building dimensions, not by the total size of your land. Standard setbacks on the side is 90cm. zero lot block means you can have your garage attached to someone's else, but just in case, please check with the banks (if you are doing finance) before continue. Read the following links for more info and make sure you have all the criteria on "How do I get approved?" section. https://www.homeloanexperts.com.au/prop ... tion-loan/ Hi Wentworth33, Thanks for the reply! I've spoken with over 20 builders and narrowed it down to 3 potential builders. I love the Maza 29 layout by Metricon: https://www.metricon.com.au/new-home-de ... oorplan=29 I have a 10 metre frontage. The house width is 8.99m which leaves the 900mm for one side (I have an easement) and 50mm for my zero lot side. (It doesn't need to be attached to the next door neighbours garage, I double checked. It's basically building right on the boundary, well, 50mm from it). Anyway, the builder said I can't do this because I need a 1.5 metre setback on one side. But so many people are telling me different things.....uh! Where are you building? I'll be in Parkside Hi NZ89, Have you check it with other builder ? Please double check with the builder and ask why you need 1.5m on the side. If not mistaken, you DO need 1.5m if you have a water tank on the side. But, why not move the water tank behind the garage ? (ie. close the garage door access to the garden, you dont need it do you ?) check it with the builder, If you dont have water tank on the side, do you still need 1.5m or 900mm ? Hope this info helps. Hi Wentworth33, I've checked with two others, but their house designs were smaller, so it wasn't as tight of a fit as the one I really want. I'll check with a few more! I guess once I get closer to the land registering, I will get my top three designs and see which council approves?! Do I need a water tank? I never heard about that..... I hope I don't need one. My lot is so small! Do you need one? What is the lot 5 series? I'm not sure of all the different stage names there. I think I'm Parkside release 2? I'm the street after Alamien Street to the right http://www.newbreeze.com.au/pdf/NewBree ... an_WEB.pdf Building in New Breeze, Stage 3 Parkside Bardia For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 10135 Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 6004 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 3093 |
