Browse Forums Building A New House Re: Building with Henley- Monaco Lux Q2- Customised 41Aug 07, 2017 6:53 am Re: Building with Henley- Monaco Lux Q2- Customised 42Aug 07, 2017 8:52 am Wow. That happened quickly. Looking good. Re: Building with Henley- Monaco Lux Q2- Customised 43Aug 18, 2017 3:56 pm Re: Building with Henley- Monaco Lux Q2- Customised 44Aug 18, 2017 4:33 pm Looks great. We've almost caught up. Guttering his week. Roof early next. Good luck with the inspection. We had our frame & slab inspection on Tuesday and there were 32 items. Re: Building with Henley- Monaco Lux Q2- Customised 45Aug 19, 2017 4:34 pm Mrs_W Looks great. We've almost caught up. Guttering his week. Roof early next. Good luck with the inspection. We had our frame & slab inspection on Tuesday and there were 32 items. 32 defects..? I'm scared now as I haven't done Slab and Frame just believe with Builder Surveyor compliance report... were they major defects? Re: Building with Henley- Monaco Lux Q2- Customised 46Aug 19, 2017 5:46 pm They should be able to check a lot of the frame at pre-plaster. I don't know if they were major but there was a lot that didn't comply with Australian standards. I copied out the items on the report that didn't comply and put them on my blog. We're Building a House! – Building our forever home with Bentley Homes in Melbourne https://werebuildingahousesite.wordpress.com/ Re: Building with Henley- Monaco Lux Q2- Customised 47Aug 21, 2017 7:25 am Mrs_W They should be able to check a lot of the frame at pre-plaster. I don't know if they were major but there was a lot that didn't comply with Australian standards. I copied out the items on the report that didn't comply and put them on my blog. We're Building a House! – Building our forever home with Bentley Homes in Melbourne https://werebuildingahousesite.wordpress.com/ I have checked those looks like workmanship was poor by contractors used by bentley... i have Darbecca coming today for Slab, partial frame and pre-plaster inspection today... will update you how it goes... Re: Building with Henley- Monaco Lux Q2- Customised 48Aug 21, 2017 7:50 am Very poor workmanship by all contractors. Good luck with your inspection. Let me know how it goes. Re: Building with Henley- Monaco Lux Q2- Customised 49Aug 25, 2017 2:59 pm How did you go with your pre-plaster inspection? Re: Building with Henley- Monaco Lux Q2- Customised 50Aug 25, 2017 3:03 pm Mrs_W How did you go with your pre-plaster inspection? I had below defects:- 1) The DPC to the dwelling does not overlap by 150mm. 2) The gutters on the dwelling all need to be fully cleaned. The roof tilers nails, pop rivets, mortar, tile mortar colour and the broken bits of tiles all need to be removed. They will at some stage cause blockages to the storm water system as they will not break down over time. 3) The plumbing pipes installed to the cavity area of the dwelling will breach the minimums set down in the bricking Standard. 4) Several sections to the sisalation paper (reflective insulation) that requires reinstating due to rips, tears and openings. 5) The vapour barrier installed has been allowed to fall down below the slab edge and has been covered by soil during the backfill process. 6) Temporary downpipes have not been installed to direct water away from the slab. 7) A number of loose strap bracing to the garage walls. Several of the jamb studs were not connected to the lintels via nailing through the jamb stud into the lintels. 9) Noted that the portico concrete slab does not present straight, reworking is required. Also noticed that the concrete slab under the bath had been opened. 10) The intersecting wall junctions have not been installed with the correct method of blocking. 11) There are a small amount of wall noggings that need to be installed or in parts reinstalled. 12) The steel earthing rod to the slab is connected to the steel reinforcement mesh inside the slab. 13) Due to the proprietary nature of the gas line and the associated fittings, the builder must install a universal T connector to the gas line. 14) A number of areas where the electrical cables are making contact with plumbing pipes within the wall frame. 15) A small number of window and door frames are presenting out of plumb in excess of the 4 mm over 2 m tolerance. 16) There are gang nails missing to a number of the top plates to the walls in the dwelling. 17) Many of the double timber frame walls to the dwelling are not interconnected. 18) The bath hob requires noggins around the perimeter to support the plaster and metal waterproofing angle. 19) The windows and doors measuring over 1500mm high have not been installed with nail fixing at the centre of the reveal. 20) The concrete slab floors to the dwelling have areas showing out of level as well as visible humps and dips. 21) Where saddle trusses cantilever past the supporting truss blocking is required to support the saddle truss. Re: Building with Henley- Monaco Lux Q2- Customised 51Aug 25, 2017 3:28 pm Some of this items look familiar as we have the some of the same defects. I hope your builder has agreed to fix them. Our roof has just been finished and we don't have temporary down pipes either and I've been told we won't be getting them... Re: Building with Henley- Monaco Lux Q2- Customised 52Aug 25, 2017 4:26 pm Mrs_W Some of this items look familiar as we have the some of the same defects. I hope your builder has agreed to fix them. Our roof has just been finished and we don't have temporary down pipes either and I've been told we won't be getting them... I have down pipes installed but not in all areas.. i guess Darbecca have raise where it was missed by builder... Re: Building with Henley- Monaco Lux Q2- Customised 53Aug 31, 2017 7:59 am All defects by Darbecca has been rectifies by my SS and he has walk through with me on Mon 27/08. Pre-Plaster and Brick work started yesterday. Lock up to follow. Come to know that my SS is going away for 2 weeks as he is getting married so someone else will be looking after in his absence. Re: Building with Henley- Monaco Lux Q2- Customised 54Aug 31, 2017 8:46 am zee1308 All defects by Darbecca has been rectifies by my SS and he has walk through with me on Mon 27/08. Pre-Plaster and Brick work started yesterday. Lock up to follow. Come to know that my SS is going away for 2 weeks as he is getting married so someone else will be looking after in his absence. As long as the handover to the temporary SS is excellent then you will be fine! At least its at a time where the bricks and plaster will take those 2 weeks and he will be back so it shouldnt be all that bad Re: Building with Henley- Monaco Lux Q2- Customised 55Aug 31, 2017 9:33 am Glad to hear that the defects have been rectified. Yay for bricks! Ours started yesterday too. Re: Building with Henley- Monaco Lux Q2- Customised 56Sep 11, 2017 2:22 pm Hi All, Just got Lock up Invoice today. 37% complete as what it says in Henley My Home page. Re: Building with Henley- Monaco Lux Q2- Customised 57Sep 11, 2017 2:46 pm Have you been given a an estimated timeframe for handover? Re: Building with Henley- Monaco Lux Q2- Customised 58Sep 11, 2017 2:49 pm No, I haven't thought of it bdw. You think should i ask my Construction Administrator.? Re: Building with Henley- Monaco Lux Q2- Customised 59Sep 11, 2017 2:52 pm I was just asking out of my own curiosity as our builds are almost on par with one another. My builder told me February, but I'm seeing other people on here moving in 3 months after bricks are completed and 2 months after plaster so still holding on to hope for handover this year. Re: Building with Henley- Monaco Lux Q2- Customised 60Sep 11, 2017 3:08 pm I am hoping end of Oct, let see what happens. My Admin come back saying sill a while for completion so no date as if now. Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 12789 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11864 |
