Hi Lenny171
We're building with Clarendon and they've charged us $300 per bathroom to lower the floor by 40mm in order to have a seamless lower level. They're also going to cut the alfresco sliding door in so that it's level.
Cheers,
David
Browse Forums Building A New House Re: Cost of stepping down bathrooms/laundry to match floor l 21Jan 15, 2014 12:52 pm Lenny171 Does anyone have any idea what builders charge to step down the slab so as the bathroom/ensuite and laundry are all the same level ( ie not step up in to them) when tiled please? Thanks Hi Lenny171 We're building with Clarendon and they've charged us $300 per bathroom to lower the floor by 40mm in order to have a seamless lower level. They're also going to cut the alfresco sliding door in so that it's level. Cheers, David Re: Cost of stepping down bathrooms/laundry to match floor l 22Jan 15, 2014 2:10 pm When they pour the slab, I thought they made the shower recess done then.... our's is going down 50mm to get the flat floors in to the shower. Don't quote me on this one, but I would've thought they put a mold of appropriate size and shape at pour time so that the slab. I guess if they pour the slab flat, then I guess must then cut and chip it out afterwards, which is all I can think as to the extra costs they are charging for it. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Cost of stepping down bathrooms/laundry to match floor l 24Jan 15, 2014 4:03 pm bpratt When they pour the slab, I thought they made the shower recess done then.... our's is going down 50mm to get the flat floors in to the shower. Don't quote me on this one, but I would've thought they put a mold of appropriate size and shape at pour time so that the slab. I guess if they pour the slab flat, then I guess must then cut and chip it out afterwards, which is all I can think as to the extra costs they are charging for it. Slabs are generally flat except for the required step downs in the garage, front porch and alfresco. The 'slant' is obtained by the tiler when laying the tiles and in most cases is fairly minimal as you don't normally need much for the the water to flow down the waste. The requirement is for a waterstop to be installed to the entries of the room, (a small aluminum 'L' angle to retain the water to within the room) can't see if they have… 1 2523 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 14444 |
