Browse Forums Building A New House Re: Home Group WA - WE ARE IN! 1421Aug 20, 2016 6:59 pm I bought that aluminum edging from bunnings, I think there are different heights and you will be able to whipper snipper up to it. I didn't want anything like blocks or similar but needed something more durable than the plastic edging. https://www.bunnings.com.au/tuff-edge-2 ... k_p3300272 Re: Home Group WA - WE ARE IN! 1423Aug 20, 2016 10:04 pm Are you still decking the portico? You could run the deck along the front too? Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Home Group WA - WE ARE IN! 1424Aug 21, 2016 1:15 am Decka I bought that aluminum edging from bunnings, I think there are different heights and you will be able to whipper snipper up to it. I didn't want anything like blocks or similar but needed something more durable than the plastic edging. https://www.bunnings.com.au/tuff-edge-2 ... k_p3300272 We have the edging down both sides to block off our block to the neighbours and keep the sand and weeds out, I wanted something a little nicer though haha I'm just not very creative archetto Are you still decking the portico? You could run the deck along the front too? I still want to deck arch but really want duralife composite but can't justify the price, just don't want the up keep of natural decking but the price is making me want to go natural. I did think the decking with lights would look good but think it will be a later job at the moment Re: Home Group WA - WE ARE IN! 1425Aug 21, 2016 2:40 pm Natalie92 Decka I bought that aluminum edging from bunnings, I think there are different heights and you will be able to whipper snipper up to it. I didn't want anything like blocks or similar but needed something more durable than the plastic edging. https://www.bunnings.com.au/tuff-edge-2 ... k_p3300272 We have the edging down both sides to block off our block to the neighbours and keep the sand and weeds out, I wanted something a little nicer though haha I'm just not very creative Yeah there aren't many options out there for this sort of stuff. For the gap under the fencing I ended up installing plinths from Gramline in rockingham, you just cut it to size. A bit of a pain installing it after the fact because you have to pull the panels out, but if you get in well with the neighbours you can split the cost. Re: Home Group WA - WE ARE IN! 1426Aug 21, 2016 3:58 pm Looking great guys, hard work pays off Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: Home Group WA - WE ARE IN! 1428Aug 24, 2016 3:08 pm Hey everyone, has anyone ever used harditex in front of a colourbond fence with texture render or texture paint on to finish? We are looking at it as a much cheaper option then brick wall. For the BBQ area we are wanting it to look like there is a brick wall rendered behind it but it seems the easiest and most cost effective is to put some posts into the ground and attach hardiflex and then either get texture coat render on it or paint with a textured paint 4 15720 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 18481 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 36651 |
