Browse Forums Building A New House Re: KDR Sekisui House - St George 1081Nov 14, 2017 8:00 pm Your Island bench is definitely not over-sized, it looks perfect to me! I'm kicking myself that we didn't widen ours!! Re: KDR Sekisui House - St George 1083Nov 15, 2017 9:00 am G’day. Can I ask if the upgrade was a lot of money. We want to upgrade the bench for the legroom as well so I am really interested if it’s a bit hit over the standard. Cheers Simon Re: KDR Sekisui House - St George 1084Nov 15, 2017 9:57 am Salfield G’day. Can I ask if the upgrade was a lot of money. We want to upgrade the bench for the legroom as well so I am really interested if it’s a bit hit over the standard. Cheers Simon We signed the contract back in Nov 2014. Total cost of kitchen design modifications comes to $5474. Addition to above modifications we upgrade following extras - ducting of the rangehood to external wall $255 - finger grip for overhead cupboard doors $80 - silk finish paint to base cabinets and overhead cabinets $900 - pull down sink mixer $197 - 40mm edging for cooktop bench 4 meters long $1575 - 2* 40mm edging waterfall ends to servery ( island bench) $1514 - increase depth of kitchen island bench to 1200mm $1536 - laminated overhead cabinet above fridge space $416 - increase height of pantry doors to 2340mm $537 - increase height of overhead cupboards to be in line with pantry doors height $835 - silk finish laminated panel behind rangehood $240 Always request for the cost of any individual items to upgrade or change ... you can always drop the item later if you don't like the price. Build Thread : viewtopic.php?=31&t=81624 Re: KDR Sekisui House - St George 1085Nov 15, 2017 10:15 am shazaw Salfield G’day. Can I ask if the upgrade was a lot of money. We want to upgrade the bench for the legroom as well so I am really interested if it’s a bit hit over the standard. Cheers Simon We signed the contract back in Nov 2014. Total cost of kitchen design modifications comes to $5474. Addition to above modifications we upgrade following extras Thank you. I could live with $1500 for the extension even though I am sure it’s still a rip off. - ducting of the rangehood to external wall $255 - finger grip for overhead cupboard doors $80 - silk finish paint to base cabinets and overhead cabinets $900 - pull down sink mixer $197 - 40mm edging for cooktop bench 4 meters long $1575 - 2* 40mm edging waterfall ends to servery ( island bench) $1514 - increase depth of kitchen island bench to 1200mm $1536 - laminated overhead cabinet above fridge space $416 - increase height of pantry doors to 2340mm $537 - increase height of overhead cupboards to be in line with pantry doors height $835 - silk finish laminated panel behind rangehood $240 Always request for the cost of any individual items to upgrade or change ... you can always drop the item later if you don't like the price. Build Thread : viewtopic.php?=31&t=81624 Re: KDR Sekisui House - St George 1086Nov 15, 2017 6:43 pm Today update, Main electrical pole installed, painters started on ground floor's walls and waterproofing for balcony floor. Build Thread : viewtopic.php?=31&t=81624 KDR Sekisui House - St George 1087Nov 15, 2017 7:52 pm Looking so good shazaw The overhead cupboards you have there is much better proportion than standard Re: KDR Sekisui House - St George 1091Nov 18, 2017 5:29 am I will have to take a pic of ours, we haven’t had it completed but I hadn’t noticed a step like that Re: KDR Sekisui House - St George 1092Nov 18, 2017 7:59 am They should have made ceiling same level. The original front ceiling was worst looking. A row of bricks was showing on both side so I asked SS to drop down the small section of ceiling and capped the row of bricks but carpenter did not capped the row of bricks. They should know how to do things correctly I should not be asking for little things to finish off nicely. There are too many areas that Painter had marked with pencil for repatching, refilling needed to be work by plaster guy. SS is waiting for approval from his management to replace incorrect size kitchen cooktop bench and base cabinets, as this was admin mistake. How long will it take to approve?... I don't want refund!!! I do wants correct size stone top and base cabinets. After looking into kitchen from different angles we needs to have full sized cooktop bench to balance off the huge island bench at the front. At the moment the 60cm cooktop bench looks short and small from distance. Definitely not balance!! Our roof tiling is still not finish!! and I told bathroom tilers to redo some floor tiling as they did really bad job. Now they are waiting for more floor tiles to be deliver. Build Thread : viewtopic.php?=31&t=81624 Re: KDR Sekisui House - St George 1093Nov 19, 2017 7:09 pm Hmm so the lintel that holds the bricks up (where the step is) should of been 1 row higher? Re: KDR Sekisui House - St George 1094Nov 19, 2017 8:21 pm You're having timber feature on the front arent you? I wonder if they could line it in timber boards to match the other timber feature, wrap it up over the step, so you see the edge as well? So its "meant" to be lower? Re: KDR Sekisui House - St George 1096Nov 19, 2017 11:03 pm Cat_dunc you have come up with great idea. builder mistake leads to my advantage. Yes ceiling should have come down to cover the bricks row, but they only fixed the smaller section of two ceiling, that why there is a step showing. I have told SS to cover bricks and still bricks are showing. With cat's idea timber feature on ceiling is a good solution. I only have timer feature at the front of balcony so should flows in So nice to have buddies on H1. hehe Build Thread : viewtopic.php?=31&t=81624 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19880 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 14151 |
