Waterproof air-conditioning slab
We have paid extra to have the ducted air-conditioning slab poured as part of our house foundation. The builders say it is our responsibility to waterproof the slab, they don’t offer to do it. Where do I find out how to or who offers this service. The air-conditioner is part of the build as a “free upgrade extra” from the builder.
The slab still needs to comply with the BCA
And it’s the builder resposability to comply with it
Have you a photo of the AC slab
There are ducting pipes inside the slab and duct vents placed will be in-floor?
If the builder offers an upgrade, he should be waterproofing it too (it should be all covered by your building contract).
You can get some clear sealer from bunnings to maybe spray on to slab , what the life span would be I don’t know it’s not a permanent barrier
It’s a design fault really and as I said it’s down to your builder to meet the code requirements it’s not for you to come up with a solution to sort out a problem for them
Part 2 of the code states you must prevent damp and moisture entering the building
You can down load a free copy of this so you can have a read up on it
Where abouts are you building ?
It looks a lot better than my situation at least you have a step down to your AC plinth
Virginia in Sourh Australia
Not quite understanding what you mean under ducted air-conditioning slab.
No it’s just a slab for the air conditioner to sit on, poured at the same time as the whole foundation, we paid extra for it, but in the contract it says we are to have it waterproofed, but it has the same plastic as the main slab, and has had the same waterproofing done by the white ant ppl. So I am at a loss to understand what blinking waterproofing they are talking about.
I don't think it requires any waterproofing at all (except possibly slab edge touching the ground), i.e. do you waterproof your driveway?
If you look at the photo you will see it’s connected to main slab so moisture and damp can penetrate up into main slab as there is no break or dpc to stop it
Where the moisture and damp will be coming from, I wonder? How do you specifically waterproof your driveway slab, which is also connected to the garage slab, etc.?
Waterproofing for concrete is only needed for below grade surfaces.
Your driveway slab is not connected to the house slab , if done correctly the dpm is extended through and then brought up the face of the slab and cut off at ground level
Giving you a barrier to prevent moisture / damp entering the slab
Down load a free copy of the ncc it’s all in there
If you waterproof the edges and under your aircon slab, how do you see the dampness entering to your house slab even though they are connected?
When you build brickwork you have a dpc to prevent rising damp and moister the dpm under the slab is the same thing it prevents damp coming into the slab , the slab is protected from the weather by the walls etc but the AC slab is left exposed but part of the slab so damp and moister can get into the main slab as there is no barrier to prevent it
Are you a trades person or builder ?
As I said down load the free ncc it explains it all in there
The point being that it’s the builders responsibility to build to code
Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small…
17/06/2023
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room…
