Building Quality Standards / Tolerances
Are there any inspectors out there that can advise where I can find the relevant standards relating to building quality / tolerances for residential construction in New South Wales?
Particularly interested in tolerances for the following:
- squareness of internal walls (horizontally along its length and vertically)
- gaps between wall and skirting/architrave
- gaps between wall and melamine shelving
Thanks.
In the meantime as Bashworth notes the Victorian version is generally accepted as a suitable guide in NSW.
If you can't find specifics in the Vic version there are details of the tolerances you are looking for in the QLD QBCC version. It is available via QBCC website.
Remember these are only guides and individual circumstances should be taken into account on a case by case basis.
Hope this helps.
3
Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished.
26/05/2023
4
I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more…
