Charged storm water system
Two of the storm water drains are full of water and the SS said this will always be the case is the drainage system is charged.
Do I screw these storm water pipes off or just i just throw a grate over them? When I fill each drain with water it just overflows.
Any help would be appreciated.
Cheers
Shanil
What do you mean by "drain"?
Some photos would be good as your description is very hard to follow.
On the storm water plan it goes back to the rainwater tank.
Ok, I have the complete picture now.
It is an Inspection Outlet (IO) but it seems to be a very strange place to put it and an archaic sub standard way of doing things.
From memory, you are in...Melbourne metro?
Have they fitted leaf diverters to every downpipe being diverted? It is important to keep organic matter out of wet systems.
Charged systems build up crud which can turn the retained water anaerobic because even during heavy rain, the water lacks the velocity up the vertical riser to flush the subsurface pipe. A wet system also won't flush through an IO due to the top of the IO being higher than the pipe.
If you browse through Eco Living rainwater harvesting threads, you will find a diagram of a simple but very effective DIY sediment trap in several threads. The thread below has a diagram at the bottom of the first (and only) reply.
viewtopic.php?f=35&t=85013
You mentioned that there were 2 pipes diverted to the tank. How many downpipes are diverted to those 2 pipes?
2
Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271
26/11/2023
Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new…
17/01/2024
1
If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a…
