Hi everyone, our slab has been poured for 3 weeks and now we spotted some thin and long cracks on the slab. They locate across the centre of the slab, from one side to the other, even extend to the edge of slab. Is that normal? Should we ask the builder to repair it? Will it cause any structural issue?
Please assist?
Thank you
TF
Thin and long Cracks on slab
Please assist?
Thank you
TF
if you want to finf out more check out this link: https://anewhouse.com.au/2012/02/concrete-cracking/
They look to be less than 1mm which is fine.
The slab uses the reinforcing steel, plus the interlocking effect of the irregular crack surface, to maintain the structural strength.
Once a crack starts it tends to run until it either reaches an edge or another crack.
Thank you for clearing our minds!! Seem we worried too much:)
I tend to disagree with the recommendation when saying the cracks at 3 months are 1mm and no cause for concern.
Firstly - do you have a soil report and who did the soil sample?
Secondly - what is the slab classification based on that soil report?
These are two very critical factors that you need to ensure are accurate due to potential issues that can occur if it has been classified incorrectly. The classification determines the appropriate thickness and depth of footings. If they are not correct, the potential of slab heave is very possible.
Concrete shrinks, they are the physical properties of concrete. Shrinkage is controlled with reinforcing steel to ensure that instead of large cracks there are thousands of small cracks mostly invisible to the eye.
Presently there is no evidence pointing to defects requiring further attention.
9
The CSIRO BTF18 explains differnt types of cracks and what "normal" is Google this and the top result is actually the latest version. You normally have to buy this from…
30/05/2023
3
The spacing of the studs looks pretty large especially for a load bearing wall.
2/07/2023
It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the…
