Min. Ceiling Height tolerance with floor coverings
Was hoping one of the learned building inspectors or surveyors or anyone in the property industry could help with some info. We are considering our options for flooring for our refurbishment. Our house is not your typical place. 60-70% of the house is on stumps with timber bearers and brushbox timber floors around 50 years old. The other part of the house is built to match the rest of the house but is partly on concrete slab and partly cantilevered using steel posts, timber bearers and chipboard flooring. It used to have carpet but we have ripped that up.
Anyway, my wife want to match the solid brushbox flooring into that part of the house (not engineered floating floor). Due to it being partly on a concrete slab, the flooring contractor will need to install plywood substrate. Problem is out existing ceiling height is around 2410-2415mm. Once we add 12mm ply and 19mm hardwood, this will reduce to 2379-2384mm.
My question is, is there any tolerance given on the 2400mm height measurement, and what actual legal issues are there surrounding marketing of the house if we ever sell it? Could a bank refuse finance to a prospective buyer if it were found out? What is the likelihood of someone actually picking it up and taking issue with it? Is this something that building inspectors regularly check?
There is a way out. The current ceiling battens in that part of the house are 40mm hardwood. I could (if I really wanted to) take these down and replace with 22mm steel battens and re-sheet the whole ceiling, but would like to avoid this if possible as the solid hardwood floors are already going to cost me an arm and a leg...
Appreciate the help.
I had a talk with the client who had a big argument with the builder over this ( and a lot of other issues ) but the certifier passed it as being fit for purpose.
Stewie
What you do afterwards, ie carpets etc, is irrelevant as far as building compliance goes.
Reduced height might be an insurance issue, best to disclose it to them.
Someone picking up 10-20mm short on the height afterwards, is pretty well negligible. I have NEVER seen a real estate agent, prospective buyer, or bank loan inspector measure this height if it is not obvious.
Stewie
9
i inspect..there is no construction tolerance or building tolerances. Your option to instruct council with your surveyors report as they would have possibly had to obtain…
8/02/2024
7
Caulking gaps that big will look horrible
12/03/2024
Hi there I'm looking for a independent company for a expert report on my blinds ,sheers & plantation shutters I'm in Melbourne
