Roof not built as designed, what do I do?
Page 1 of 2
The roofies built the roof to the edge of the pillar, and the people who were doing the gutters then put their gutter on the outside, now from the front of the house, there is a pillar with a gutter randomly sticking out the side of it. It does not look like the elevation written on the drawings, where the pillar is a straight beam up and down.
There is a section detailed in the working drawings of exactly how to build the roof in this location. In fact this gutter itself has a detail all of its own including dimensions of how to place it.
Additionally, the lower section of the roof is also not built to specification. The section details very clearly how it is meant to look from both sides of the pillars.
I will post pictures of the section and floor plans which clearly show the extent of roof over is setback from the pillar's corner if required.
The builder told me they would not rectify it because it's impractical to remove the roof and replace it. I would tend to agree it's impractical but it's not built to the clearly specific engineer's details which were provided. I guess there's something in the contract I signed which means they can clearly not build it as specified if it's too hard?
The question is, what do I do?
In your case it seems that architectural appearance of your home has been altered without your consent and builder is now saying "too hard to fix tough luck".
You are well within your rights to demand that plans be followed however you may need expert help to compel your builder as he may try and ignore and bluff you.
building-expert... no posts on your blog this year!?... you must be a very busy man!
Yes, too busy and being told to slow down to enjoy what I have, I will be 65 in 3 months (good advice)
I have been taking a week off work every month for the last 2 years and soon the plan is to be week on and week off
Most likely I was suffering from writers block for blogging but then I have been posting a lot on this forum.
I still have a million stories to tell so keep checking
Sounds like you are having a bad run with supervision and some of the trades.
Please put up the photos, although roofs and gutters are a tough one, and it's often accepted that designers make mistakes and it is something clients can live with, did they have separate details for the front pillar? In the end it often comes down to how much you are aggreived at the out come? As for Structural defects I advise all clients to explore that possibility first.
My bet? Builder will have to do the pier again.
I have scaled up the plans in Bluebeam though, and the drawings have the rendered elevations with 890 width:
The right pier (as per section y-y) is 900 X 325, the left pier is 900 x 318. The middle pier is 915x515. The distance between them is 1670.
Obviously none of these measurements match the plan, most notably the extra pier depth and width.
also there are no dimensions on your plans
There are definately dimensions. The scale is given in the title block and also in the drawing itself. The section Y-Y is scaled 1:50@A3 and additionally there are dimensions specified which can be scaled off, even if the scale was not given. The section may not have all the dimensions specified but they are easily measured using basic measurement tools scaled off the dimensions given for the ceiling level in the Y-Y section, which also does match 1:50@A3 scaling.
There are also dimensions given for the 100mm window mouldings in the elevation drawings which I calibrated from to get the measurements which then match the ground floor plans which do have the dimensions given, so the drawings definately all match up with measurements.
I am just still trying to figure out what went wrong so I can attempt to get it rectified. It appears as though the piers are built too wide, especially the middle pier.
3
Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful
29/07/2023
We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some…
9/08/2023
1
Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry…
