Protecting your Slab
Page 25 of 28
I've just reread this thread for about the 3rd time to refresh my memory before my build starts. I am posting to bump this thread up for anybody about to build to read from start to finish. It outlines some of the issues to be aware of. My advice is for anybody about to build is to organise for a pre-pour independent inspection as once it is out of the ground and set in concrete and is wrong you are in a world of hurt.
Could not have said it any better myself!
There are some concrete or paved areas on either side (but not everywhere) so I'm wondering what I would have to do for the parts where my footings will abut on to my neighbors garden bed for example.
Stewie
For those about to build read this thread from A to Z. Far more important that the colour choice of the walls in your new house.
Most people see this thread after issues arise. perhaps promoting this thread outside of this thread might highlight its importance to a broader audience.
I agree 100% but have no idea how it can be in everybody's face without continually bumping it up.
Request a sticky.
How do you request a sticky for this thread?
If it is going to be made a sticky, then it really needs to be moved to the more appropriate sub forum, i.e. building standards I guess.
You also have to remember that the admins have to be really selective as to what they make sticky, as it's no good to have a dozen sticky threads in a sub forum as they lose their effectness, and often spoils/becomes a nuisance for people trying to read new posts in that sub forum.
It becomes a case of damned if they do, damned if they don't.
FWIW, I reckon the better option is to move this thread to a more appropriate forum, i.e. Building Standards. It then won't scroll off the first page with the dozens of daily new posts that it would in the Building a new home sub forum.
This might be a silly question but is there an alternative to concrete around the slab? Would compacted road base under pavers be enough? Is there any safe way to have a garden bed directly against the slab?
With plastic sloped away you can put anything on top as long as it doesn't puncture the plastic
Builders plastic is good maybe even doubled up to be sure.
As far as a garden against the house wall goes nothing that needs watering and very shallow roofs that won't get through the plastic so realistically flowers or ground cover plants that don't need watering.
If you look at the drainage crossection posted earlier and remove the concete and replace it with gravels and topsoil that's what you should be aiming for
Yes as long as it is done properly and slopes away from the building.You could slope the plastic into an agi drain away from the the perimeter.
The area below in red will be concreted and drained. Ideally I would like to have lawn right up to the alfresco with subsurface drainage, without a concrete apron around the alfresco as well . Is this a bad idea or should I just concrete the green area (1m wide) as well??
Thanks
My house is nearing completion and I am arranging concreting and drainage all the the way around the perimeter.
Thanks
Thanks
Thanks
Thanks
Is that correct? Only 25mm fall.
Some say it's 75mm fall. Hmmm
6
Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely.
12/06/2023
1
The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists.
