Building surveyors – what they won’t do
As both the builder and the building designer have relied on his certificate of occupancy to claim that the house complied with the building regulations I find his response ridiculous. We have a situation where the builder and the building designer can rely on the validity of a certificate to cover themselves which relies on their integrity in the first place!
As I have been surprised by what the building surveyor doesn’t know about our build, I just wanted to check that he’s not just having me on.
So our building surveyor will:
approve plans for a 3.6m wall on boundary even though the site levels have only been estimated and there is no guarantee the house can be built
not be aware that site levels were incorrect even though he had to approve your amended plans
not require the amended plans to have revised site levels on them so that the proper floor heights can be worked out
not notice if slab heights vary from the approved plans
not notice the absence of freeboard and whether land has been graded away from the house
not notice if the overflow relief gully doesn’t have the right separation from ground level
not notice that you now need steps to the front porch deck and a retaining wall at the back (which has only become apparent now that you have excavated the land to the right level!)
give approval for a deck that covers weepholes
Anything else he won't do?
Bozos like this are what give the building industry a bad name.
I'm lucky in my dealings with some of the local private certifiers who mostly seem to want to cross every T and dot every I almost to the point of being pedantic - but the builders on their jobs know exactly where they stand. Every deviation from an approved plan is documented with new floorplans and elevations as well so there is no confusion for anyone concerned.
I think this sometimes comes down to how well the original construction documents have been drawn as well. Some I've seen leave a lot to be desired and only cause confusion for all concerned.
Stewie
I should add that the building surveyor was the designer's choice. We wanted to use the local Council Surveyor as his fee was considerably less than these fellows- approx. $700 instead of about $2,000. The building designer didn't want to as council surveyors require “details” she considers “unreasonable”. We were told that, if we chose the council building surveyor, she would charge “extra for the extra time to document” if this proved necessary. It's hard not to come to the conclusion now that she chose them because they don't ask too many questions.
http://www.buildingcommission.com.au/__ ... 013_62.pdf
and it makes very interesting reading. It may of be use to others. It says, amongst other things:
"the Registered Building Surveyor must not supplement or augment the application of design documents by ...correcting errors"
Our plans are annotated in red everywhere by the Building surveyor.
It also says:
Site plans must include:
site levels and contour lines of the allotment
Ours didn't.
It also says:
"Where the roof truss design is to be submitted after the issue of the building permit, the RBS must include a condition on the building permit that the roof truss details and layout plans are to be submitted prior to the installation of the wall framing.
Ours doesn't and there was a big stuff-up with the roof framing.
It also says:
"The stormwater drain layout must clearly show the required fall, cover to pipe work, downpipe locations, pits, inspection openings (IO), agricultural drains, the connection to the LPD and any other details necessary for compliance."
Ours didn't and I have spent 18 months chasing the builder and the building surveyor for a proper drainage plan. Of course, if the ground had been at the right level, we wouldn't have needed a drainage plan because we could have seen the pipes!
So the building surveyor came from the same school as our builder and building designer - the College of Can't Be Bothered.
It sounds to me like he hasn't performed due diligence.Bozos like this are what give the building industry a bad name.
Stewie
Stewie
+1 This clown needs to be brought to account. Obviously he and the building designer are scatching each others backs and cutting corners. Not unheard of.
Have you checked his registration? As you know, there were a few unregistered ones running around until recently, one reason why the Victorian Building Commission was replaced last year.
Working for such a low cut rate would have had my alarm bells ringing. You were also coerced into using him by your 'designer' and it is apparent that your 'designer' was not acting in your best interest, only their own. Very unprofessional.
You could not have worded that any better.
Yes I have checked. This appears to be a reputable and experienced company. That is why I'm just thrown for a loop. Mind you, none of the actual surveyors visited the site. They use their building inspector for visits but the surveyors would have approved the documents surely.
Let's face it. Most of the defective work is done by people who are registered. It would be just too easy if you could catch them out doing something as blatant as working unregistered.
No, it was the council building surveyor (we didn't use) who would have charged $700. The people we did use (chosen by the building designer) charged $2,000. Or is even that considered a low-cut rate?
Hope all is now clear!
"Yes I have checked. This appears to be a reputable and experienced company. That is why I'm just thrown for a loop. Mind you, none of the actual surveyors visited the site. They use their building inspector for visits but the surveyors would have approved the documents surely."
Yes reputation is a wonderful thing but it also can be deceptive and give you a false sense of security leading to blind trust. A train called blind trust could take you over the cliff.
I have learned to be sceptical about reputation because I mostly deal with disreputable things done by reputable builders. In fact I no longer believe it, I just think you are only as good as your last job.
Reputation can also be very dangerous because it is a mother of vanity feeding own egos and false beliefs they are better than they actually are. "Trust me I know best" Really?
Reputation is essential first stop, after that catch a train to project control.
http://www.vba.vic.gov.au/2016-changes- ... -surveyors
http://www.vba.vic.gov.au/__data/assets ... 160616.pdf
I wonder whether 8(ii) in the checklist would have made a difference to our situation? Would "a survey plan of existing site conditions" include a contour survey?
The first thing I insist on when a client engages me to draw plans is to get a contour survey done of the property in question. This will give you all the features necessary for an accurate site plan.
These will usually include
- contours at 500mm increments
- any features like trees , their species, height , spread of canopy etc
- outcrops of rock
- all boundary fences, retaining walls etc
- any services on site like underground cables, mains sewers etc
- easements
- floor levels of the existing dwelling ( if any ) and neighbouring properties
- outline of neighbouring dwellings that face the property including roof lines and slopes, eaves heights, ridge heights etc
- window sill heights, location and levels of neighbouring dwellings ( these are especially useful when I do the relevant shadow diagrams to show how the new house/addition will affect their solar access)
- spot levels around the property every 3m or so - all to AHD and a benchmark on the kerb
- boundaries pegged on at least one side so you know exactly where to build to ( fences are notoriously out and should not be relied upon as an accurate reflection of where the boundary actually is )
- Any other predominant geographical feature etc etc
Our local councils will not even look at a DA unless an extensive contour survey has been done. It makes it very hard for a builder/concreter/landscaper/drainage plumber to get it wrong when all this info is readily at hand although amazingly some still do!
Stewie
2
Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder…
