Build not to plans - advice needed
You may want to see a construction lawyer.
If the engineered retaining wall plans were part of your contract then yes they should be built as per the plans.
you do need to make sure they were built to plans to ensure they will be fit for purpose.
If you are planning a garden in the back and the walls are built well you could consider consulting a landscaper and getting clever and plant them out so looks like a lush green area and blocks our neighbours. If they are too narrow you cannot plant much in them.
Best of luck
Hi Redders,
Not sure where the renovation was made, or what particular type of construction contract you have, but in any case, it’s always best to refer to your contract and check the clauses on variation, defects, delay, rectification. Then talk to your builder and try to see if you can reach an agreement on how to rectify the situation. You may also check these out: Breach of Construction Contract, Building Dispute Resolution; but they apply specifically to NSW.
Alternatively, you can try bringing your matter to a specialist construction lawyer in your city, who can look into all the nuances and details of your particular situation, and dispense legal advice accordingly.
Cheers
Cheers
Yes it’s been coming up a year. They don’t work fast but having said that. They’ll get us a builder to finish the job.
It’s a long and frustrating experience!!!
Hi, glad it could be sorted. We ended up terminating the contract and the Qbcc also found in our favour. But then the builder asked fir an internal review so now waiting another month.
Oh no that is terrible. I just don’t understand why they don’t do it right in the first place
Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I…
19/05/2023
3
Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished.
18/02/2024
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
