Browse Forums Building Standards; Getting It Right! 1 Oct 16, 2010 8:56 am Hi All, I feel like I've been having some mixed outcomes with my builder... I'm doing a custom build and was sold on quality being a key differentiator. Some poor examples include:- [*] studs at 600mm, when we specified 450mm on plans, [*] insulation being sliced and diced due to ordering mistakes, that I had to go back over it myself to fill numerous gaps, [*] no expanding foam around window frames - did it myself [*] The workmanship was rough on the frame and an independent inspection picked up numerous problems. Each time I raise a point with the builder his first reaction is to belittle my opinion and attempt to bully me. If he was just open to admitting a mistake, I'd be more inclined to trust him like he expects... Now I feel like I cannot even ask question without being concerned he will do his block again and use his multitude of tactics to make our build process difficult and more expensive. I welcome any general advice, but my specific question, is I have noticed the brick work leaking in the garage and not sure if this is normal? I can only assume it is leaking between the bricks and internal walls also... Thanks Re: Bricks leaking 2Oct 16, 2010 10:03 am When you say leaking, do mean when it rains there is moisture droplets on the inside of the wall? Are you sure there is a cavity? Where you are coming from is where you are going to... Re: Bricks leaking 3Oct 16, 2010 2:08 pm Yes, when it rains the water gets through the brick wall in the garage and runs down the inside wall. Its not like a river, but if as planned i put shelving against the wall, stuff would get wet and go mouldy. The brick is a split face brick. There is no cavity in the garage on one wall, which I'm referring to. I therefore assume it is also running down where there is a cavity. Re: Bricks leaking 4Oct 16, 2010 2:08 pm Yes, when it rains the water gets through the brick wall in the garage and runs down the inside wall. Its not like a river, but if as planned i put shelving against the wall, stuff would get wet and go mouldy. The brick is a split face brick. There is no cavity in the garage on one wall, which I'm referring to. I therefore assume it is also running down where there is a cavity. Re: Bricks leaking 5Oct 16, 2010 7:10 pm There is no cavity in most garage walls, they are single skin A siloxane treatment will fix it. PM me if you want some details to fix it... yes you can DIY it. Where you are coming from is where you are going to... Re: Bricks leaking 6Nov 27, 2010 7:12 pm i have the same issue with my garage. Moved in almost 2 years ago and since winter started there has been few incident with water leaking through the garage side wall on the ground level. The garage wall is double brick. Since the first and second leak we have put silicon at the base level where water is leaking. I have taken few photos and send it to H####### , hope they will send some one out soon to fix this problem. DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25101 My first suspect area is at the bottom of the harvested downpipe furthest from the tank. PVC downpipes expand and contract with heat and cold, putting pressure on the… 3 2467 8 4473 |
