Browse Forums Building Standards; Getting It Right! Re: Incorrectly installed home gas pipes 3Dec 04, 2016 12:32 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Incorrectly installed home gas pipes 5Dec 23, 2016 11:18 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Incorrectly installed home gas pipes 7Dec 23, 2016 2:33 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Incorrectly installed home gas pipes 10Jan 12, 2017 6:27 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Incorrectly installed home gas pipes 12Jan 12, 2017 7:41 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Incorrectly installed home gas pipes 13Jan 12, 2017 7:48 pm Yes, you're right SaveH20. There should be somebody overseeing these rectifications. Once again homeowners are just left floundering around trying to get the correct information. The plumber who came today is licensed to do gas fitting. I checked up but he is very young. He even suggested at one point just painting the pipe with UV paint. How many other people have been offered these fixes and accepted them? Re: Incorrectly installed home gas pipes 14Jan 12, 2017 8:09 pm That is the worry and most won't be as aware as you. One would expect there to be a paper trail back to the VBA but is there? The VBA falls down in so many areas..... Being offered a gal pipe is an insult and the continual examples of a lack of regulatory knowledge by so many plumbers is indicative of an industry in crisis. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 4 6162 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 6034 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11319 |
