Browse Forums Windows & Doors 1 Mar 14, 2008 6:49 pm Just a general blind question about gaps at sides of blinds
I can get a standard blind that is 1800mm wide and not need to alter it or I can buy the next size which is 1950 wide and adjust it. The window width is 1810. If I buy the 1800mm wide blind I will have a 10mm gap each side and if I buy the 1950 I can adjust it so I only have a 5mm gap. I have this delima with about 9 of my windows. The diffrence will be about $600 to the window costs for all. What do you think. A 5mm diffrence does not seem worth it. Re: gaps either side of wooden venetian blinds 2Mar 14, 2008 6:57 pm Depends which direction your windows face! If you are putting the short ones on your windows that get ALL the afternoon sun……you may regret it! Internal and External - Building and Colour Consultant Online - Global www.denovoconcepts.com Re: gaps either side of wooden venetian blinds 5Mar 14, 2008 9:32 pm Definitely get wider and adjust it. We had wooden blinds in our last house that were slightly shorter on the sides and they looked ... well not too good It was worth the extra expense. It looks strange if window coverings dont actually cover the window, as the light shining around the blind exaggerates the poor fit. Try and get them as close to the reveal as possible. IMO Thanks for your reply. The builder has made the border frame above the door a bit thicker. So it looks visually level now 8 36004 Looks like it just needs proper sealing rather than anything major. Usually a clean-up and a flexible exterior sealant/caulking does the job worth asking the builder if… 5 6328 Building Standards; Getting It Right! From a Brisbane perspective this looks pretty familiar on a lot of slab-on-ground places up here, especially around that 8 to 15 year mark. What you are probably seeing is… 1 2503 |
