Browse Forums Paving & Concreting 1 Oct 16, 2015 9:03 am G'day folks We have had a quote for our driveway, we are in Adelaide and have not been able to get another quote so far due to no shows or people turning up but not getting back to us with a quote!! Anyway I just wondered if anyone could give an idea of how fair this quote is (seems ok)...basically we are unsure whether to go exposed agg or pavers. The area is 120 sq mts and the quote we have had is: $1,290 - prep $1,200 - supply and install new invert $12,144 - supply and install exposed agg 120mm thick (basically 92 per metre plus GST) For pavers instead 80 per metre so $10,560. Any feedback would be great. Thanks TL. at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61894 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 17320 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 29129 |
