Browse Forums Bathrooms and Laundry 1 Mar 27, 2020 4:54 pm We have water damage to the walls in a shower at a rental property. Only just brought to our attention and it's looking bad. The plaster walls are warped and four lower tiles have popped off. Lots of mould. Plan is to renovate the shower complex and replace walls and floor and start again, but we don't want to start that project now, in case it's stalled by a coronavirus lockdown and it's left half finished and the house is unliveable. Any suggestions to help it look better for a couple of months until we can reliably engage a tradie to do the job properly? Can't stick the tiles back on because of the curved shape of the wall. Would be so appreciative of some creative and knowledgeable ideas. TIA. Re: After a temporary fix for damaged shower 2Mar 27, 2020 5:46 pm You really need to find out where the water is getting in? The waterproofing may be defective but it could be a leak in the wall at a pipe joint or something. If it's a leak you need to get it sorted or you are in for a mountain of expense if left. If it's the waterproofing and tiles that have gone then you could do some temporary fix but as it's a question of how good you want it to look and how much you want to spend. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: After a temporary fix for damaged shower 3Mar 28, 2020 7:52 am Thanks. Pretty sure it's the tiles and waterproofing that have failed. What could a temporary fix look like? Obviously want to keep costs low, given it will all be replaced once covid lockdown is lifted, but tenants have to live with it in the meantime too... Re: After a temporary fix for damaged shower 4Mar 28, 2020 6:10 pm If it's just the tiles and waterproof membrane that has gone then you could effect a repair by covering the effected areas with one of the waterproof solid shower wall products like acrylic sheet from Bunnings or Laminex aquapanel that is available from Laminex. https://selector.com/products/aquapanel ... -panelling You would just need to make sure you used liberal amounts of silicon to prevent water getting behind the temporary sheeting. If you haven't done anything like this it's probably better to get someone in that can give you a decent finish and prevent further water damage. You will destroy the tiling to get it off so be prepared for this to be only temporary and a short term fix Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 4137 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 2045 It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2438 |
