Frameless shower screen design - will it leak?
Rectangular shower, 1900 in length, three sides are tiled. Frameless shower screen 1900 from wall to wall. Ceiling mount shower each end.
Design A: 600 fixed glass, 700 door, 600 fixed glass. I.e door in middle.
Benefits: Symmetry
Concerns: Both showers could technically leak under frameless door (as there's only a 600mm fixed piece before the glass door starts)
Design B: 1200 fixed glass, 700 door off wall.
Benefits: one shower (fixed 1200 piece end) will not leak - this can be regular shower. The second shower is likely to leak under door but this should will be used infrequently.
Concerns: Symmetry
Which design would go for?
Just did a google search and here are some examples (I'm not affiliated with this store):
https://www.yss.com.au/products/shower_screen_water_seals.php#10mm_glass_1000mm_length
Then I would go with Design A, to keep it symmetrical.
1
Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it
7/09/2023
2
If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while.
