Shower Wet Area
just after some knowledge here when we were building our supervisor advised us that a wet area is designed to always be wet ie constantly wet. Is this correct? The main reason I ask is since we finished building 2 years ago we have never used our ensuite shower we just use the main bathroom shower. Im just wondering if we never use it and then one day decide to use it could our wet area become damaged un useable due to no use over the past 2 years?
The base and the lower part of the walls should be water proof, that is designed to prevent water penetration if the area was permanently wet. (that is not to say that the area should always be wet)
Rather than water resistant, which is 'it will not be damaged by occasional surface wetting' (This would describe the tiles high up on the wall which typically don't get waterproofed as the tiles and grout protect the plasterboard)
CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.…
18/07/2023
1
All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers.
11/05/2023
1
Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow…
