Quick advice needed - bathroom floor
Father has just started a bathroom reno and offered myself up as his gopher. It's an old bathroom (early 80s) so in desperate need of a makeover.
Lifted all of the floor tiles to reveal a very sandy concrete - soft and uneven. Around the vanity there were a few breeze blocks and probably a 4" drop to the pad (no sandy concrete inside vanity space - just a nice big hole).
My opinion is that we should blow away the sandy concrete and redo cement floor from scratch prior to anything else. Dad is keen to avoid the extra effort and cost and has suggested filling in the hole then going straight to a thick screed.
My view is it's worth getting rid of it and starting with the best possible floor surface so it lasts. Anyone willing to throw in an opinion from experience?
Cheers
EDIT: Also wanted to add the existing sandy concrete is not typical. Pale yellow, extremely sandy and soft. Almost like a sandstone.
Is this a concrete slab on the ground or a suspended slab just in the bathroom area ?
Stewie
Have included img below (hopefully it works). I agree, best thing is blow it away and repour. Spend the time getting it right now so there are no dramas down the track.
Edit: Have since discovered water seepage in shower recess, so will have to cut out a large section and expose pad. Father still not keen on blowing the whole lot away - makes no sense to me given we need to grind 20-30mm off the top anyway. Oh well...take short cuts and pay the price later.
1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer…
18/08/2023
3
Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on…
2/04/2024
1
This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe…
