removing shower screen from tiles
The small shower screen (looks a few years old/patterned glass) is sitting on (attached) a raised tiled step-over section.
The side edge is attached to the shower wall tiles, where they end.
There is a silicon bead/strip at these edges, but I don't know how the metal screen strips/edges are attached to the tiles.
The opposite end of the shower screen has a shower curtain metal rod, which is attached to the wall.
I would like to be able to remove the screen and rod, then re-install it, once the new tiles are in place.
Any ideas how to remove it?
There may be some small screws or pop rivets holding the screen into the receiver. Remove these cut the silicone that holds the screen at the bottom and remove the screen.
There will be screws inside the receiver holding it to the wall, remove these cut the silicone and pull it off.
1
Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it
28/07/2023
7
The best advice is for you to get a competent building consultant to guide you through your build
