What to use to seal bath tub drain
Pictures would be a great help!
https://encrypted-tbn1.gstatic.com/imag ... VFsjoISOPE
That's what I have see the rubber ring and then the nut at the bottom im guessing that's for under the bath do I use and silcon glue for the stainless steel bit on the good surface of the bath tub?
They normally supply two rubber rings one for either side.
The one under the waste plug(inside the bowl) usually leaks so my plumber throws it in the bin and installs with silicon.
I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old…
16/07/2023
4
Thanks mate, this helped a lot. Managed to get it back in.
27/06/2023
4
Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for…
