Shower head???
Page 1 of 2
If you just wanted hand held without the rail like the one below - I wouldn't think it's a problem
Problem you are going to have that the rail will not be centred along the wall due to the outlet already installed for the shower is in the centre. Usually when installing a shower on rail the rail goes in the centre and the outlet for the water is to the side. They usually install a chrome elbow with a flexible tail
Regards
Shane
Correct to a certain degree.... Some showers, yes, are installed as above so if you want to be able to install after handover you may have your shower off centre. There are other options out there where you can actually have the top 'bracket' screw onto the the existing thread coming out of the wall. There are options,just fewer to choose from.
Ive asked my builder to just keep it standard but ill see if i can move the shower rose to the side, and replace it with a nicer one after....It doesnt seem to hard actually.
Now to go on the hunt for a decent handheld railed shower head!
They are going to replace it, but now after reading this thread realise it's all going to be off centre.
thats a bit annoying that your builder didnt pickup up on the fact you probably upgraded to now have an off centre shower!
My builder is charging me to move mine from the centre so i can replace it after handover...
never can win.
It didnt cost to move the shower spout across, so moved it to the Right hand side.
Not sure if they liked the fact Im doing it after H/O
Now to find a nice shower with rail!
Besides, the energy saving tip suggests the shower be as high and away as possible to let you enjoy more water in the same flow
ITs not that bad having it like that really and you probably wont even notice after too long.
I wish I didnt do it in the bathroom but at the same time its good for cleaning and whatnot.
Does anyone know a good website or place to buy decent handheld rail shower spouts?
I got the plans back - they have moved it to the RHS (Right Hand Side) but it has not been moved down, its still at the same height a normal shower rose is.
Should I move it down an fraction so its lower than the shower rail height?
Thanks for your help
but... the most useful thing ever I find is... because im short I like the shower head lower so I dont get my hair wet.
DP is tall and likes it high because otherwise he only gets a half shower.
Worst thing all is the temp, if we share a shower, i like it hotter because I cant feel the warmth as much. The closer you are to the showerhead the hotter it is....
xquisite, they are great for cleaning yes!!
+ 1
2
I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks
23/07/2023
11
If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that…
22/06/2023
Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to…
