need a P Trap toilet suite, 220mm high
can any one tell me where I can get a P Trap toildt suite, the wall-outlet is 220mm high from middle of waste to the floor. Urgent! I am in Sydney.
Thanks.
Nothing special about ours though, but only $109.00
The Caroma Profile close coupled is 185mm high and when you allow for cement bedding, would fit into the 220mm high that you have.
We have one left at $270 normally over $300.
10
If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you…
13/06/2023
3
It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required…
12/11/2023
13
Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini…
