Browse Forums Bathrooms and Laundry 1 Apr 16, 2024 8:21 pm Have had a few issues with out recently done bathroom floor. Probably around 18 months old Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ First there has been been a crack running through a grout line which I put down to the floor flexing too much. I was going under the house to check and measure to put some more joist in to reduce the flex and noticed this strange residue on the underside of the compressed cement sheeting. Any thoughts on this? Is the waterproofing compromised or possibly some moisture from the underside reacting with the sheeting? There is an overflow of the storm water which has had a workout lately possibly intruding some moisture? This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 16118 ![]() Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 5578 Our external decking was only installed 2 months ago, and already moulded, with cracks, and some timber decolorated. The decking is in an exposed area, uncovered in our… 0 3315 |
