Browse Forums Heating, Cooling & Insulation 1 Jun 24, 2013 9:44 am Hi all, I've asked several experts about my roof and each has given me different information - I want to put in new sisalation and some insulation batts, but have a flat roof design, ie. very low pitch - so does this need to be taken into account when choosing products? Apparently foil backed roofing blanket is better for condensation control in this case, rather than normal foil. Is this true? Leisa - mum of two, graphic designer and printing guru. Re: best condensation control / sisalation - flat roof 2Jul 03, 2013 2:01 pm Hi you can use a product called aircell its a bit more expensive but you can find generic products on ebay and that now which are the same price as the foil blanket usually around $4m2. you can find some articles on this website about insulation http://solacebuildingservices.com.au/ Re: best condensation control / sisalation - flat roof 3Jul 07, 2013 8:36 pm leisadent Hi all, I've asked several experts about my roof and each has given me different information - I want to put in new sisalation and some insulation batts, but have a flat roof design, ie. very low pitch - so does this need to be taken into account when choosing products? Apparently foil backed roofing blanket is better for condensation control in this case, rather than normal foil. Is this true? The short answer is Yes. The foil backed blanket is better than foil alone because the insulation part reduces the heat transfer upwards to the colder metal roof which reduces condensation. That may not be exactly how it should be explained but its my interpretation of dew point and heat transfer etc. Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5212 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7711 4 2106 |
