Browse Forums Heating, Cooling & Insulation 1 Feb 16, 2010 8:04 pm Jo Settled In - Home Search and Relocation Services - http://www.settledin.com.au http://www.movingbacktotassie.blogspot.com/ viewtopic.php?t=9571 Re: Evap cooling - where should the water go? 3Feb 16, 2010 9:09 pm Jo Settled In - Home Search and Relocation Services - http://www.settledin.com.au http://www.movingbacktotassie.blogspot.com/ viewtopic.php?t=9571 Re: Evap cooling - where should the water go? 11Feb 22, 2010 1:47 pm Lets Build has come the closest to the answer. However that pipe is probably put there as a vent pipe. In SA it is not legal to discharge it to stormwater (street gutter) and since many rainwater tank users drink their rainwater (including me) that is not the place for it either. The simplest, best and easiest method is to drill a hole in the sewer vent pipe above the roof level and put it in there. Plastic pipe, no rusting gutters, no contamination. Only disadvantage is to check the bleed-off flow you need get on the roof. i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16026 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20920 I've decided, after a period of confusion (my building broker told me it's probably not worth it to use a lawyer, but others have said it is a must) that I definitely will… 7 27957 |
