Browse Forums Landscape & Garden Design Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 41Jan 29, 2016 12:40 pm So, quick update: Have ordered 4 x Atlantis Grow Wall 4 Kits online (from East states) @ $195 each + $150 delivery (Total $930). I was quoted around $450 a kit from some Perth distributors Each kit has comes with 6 modules (each module has space for 3 pots) there for all up 72 pots to fill! Also, pizza oven and stainless steel door ordered and to be picked up next week! Retic & lighting cables to be installed in the next 2 weeks along with waterproofing and a whole lote of sand/soil relocation/removal before i can have paving installed in about 2-3 weeks. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 42Jan 29, 2016 4:35 pm wrexter Super Nes Definitely following this one Have you purchased your strip lights yet? Interested in where you found the cheapest No haven't purchased any lights yet Looking at getting all of my LED lights and transformers from lighting Illusions There are cheap led strips from eBay but now sure on their quality . At the moment im leaning towards RGB strip lights from LED Central. I have also purchased a RGB controller. I will be able to sync the led strip lights with my sound system I purchased quite a few of the 12v waterproof rgb and warm white waterproof strip lights and they have stood the test of time. Ali express came in handy for my spotlights. I purchased 20 12v 3W led spike spotlights and they work really well. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 43Feb 15, 2016 12:43 pm Hi Wrexter, Your backyard build looks awesome! I was thinking of doing something similar to your design. Any chance you have the measurements used for your footings? Thanks Malibu Build - Aveling Homes The Glades Estate Byford Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 44Feb 15, 2016 12:46 pm Josh604 Hi Wrexter, Your backyard build looks awesome! I was thinking of doing something similar to your design. Any chance you have the measurements used for your footings? Thanks Hi Josh, I can send you a dimensional drawing Essentially footing were as follows - 120mm thick - 7mm square mesh (50mm recess from sides) - 50mm offset of footing from brickwork Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 45Feb 15, 2016 3:44 pm Update: Completed waterproofing (photos later) and commenced the retic installation. Did a whole lot of shifting sand last weekend, i think i got rid of about 3 cubes! I started the retic and connected the lines up to the valves, only to discover leaks at the brass gate valve, and that the pvc ball valves (red handle) were not pressure rated so i had to purchase new ones and re-do that whole section (pics not shown below of new section). When i was at Bunnings getting new PVC cement, to my horror i discovered i have been using the wrong PVC Cement, the blue one which is NOT pressure rated. The green ones are for pressure piping. So i was left with the dilemma, rip out and redo or risk it. So i ripped it out and redid it. I had to or i would forever lay awake at night! Photos below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cobnnecting to the water line (coming from the master solenoid valve that was installed for the front landscaping). The 5 core wire goes to my controller. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ lots of digging, i need a trenching shovel Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Making the connections (you can see the blue joints, i had to re-do these) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Setting out my valve & fertigation setup for size....just fits in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Preparing the base Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laying my assemlby in the right spot Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wiring - what a mess Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thats better.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Running the lines 4 stations: 1. Zone 1 (Entry side garden bed, planter box, feature planter box,pot) 2. Vertical Garden Wall 3. Grass 4. Zone 2 (Garden bed around grass area, laundry side garden bed). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Finished up, ready for paving! Hoping to complete laying out all the retic and lighting cables next weekend and install the pizza oven! Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 47Feb 23, 2016 3:44 pm No progress on the retic last weekend as i had to focus on waterproofing, sealing the planter boxes and installing the pizza oven before the rains on Monday so it was a very busy weekend. Hoping to do the following this weekend: - fill up the planter boxes with sand (bring down sand level in decking area). - complete preliminary retic/lighting wiring install - waterproof top of bench seats. - Mark & clear areas ready for paving. here are some photos: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Prep work before pouring concrete for bench seats. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Planterbox waterproofing Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Planterbox waterproofing Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Pizza oven installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have poured concrete around the base of the pizza oven to bring level flush with outer brickwork. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 48Mar 06, 2016 4:36 pm Hi Wrexter. My name is Amir and I have been a landscape professional for over 15 years. I love what you have done in your yard - it looks great! I am a supplier of vertical gardens and have a product that is slightly different to what you have pictured. My system is still made up from individual pots that can be clipped into place using a mesh backing. The pots hold about ; litres of soil so are still large enough to allow plants to thrive and convenient enough to allow you to move plants around with ease. If you have not purchased your vertical garden yet, I would love to be in contact with you and see if we can help you with your design! Our system works well for the DIY handyman. If you get a chance, have a look about website. www.upthewall.com.au and see what we can do. From there you can click through to our Facebook page to get some more inspiration! I can be contacted on 0428 550 999 or by email amir@berger.net.au I look forward to hearing from you! Amir. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 49Mar 06, 2016 10:07 pm Hi Amir Thanks for the post, but unfortunately i have already purchased the Atlantis system. Also, wall dimensions were based on the Atlantis dimensions so i can not switch to another system. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 50Mar 10, 2016 12:55 pm you have done a great job mate, following with great interest. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Rendering Complete 51Mar 10, 2016 1:09 pm Thanks mirz, its a very testing project! Here are some more photos of current progress: - Electrical & Retic complete. Ready for Paving to go down in a week. Going to spend this weekend filling up planterbox with excess sand to reduce levels for decking. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Had to develop my own waterproof connection (soldered, then stuck in clear tube full of silicone) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Pizza oven tiling complete. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 52Mar 12, 2016 12:39 pm Wow. Looks great. When's the first pizza party? Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 56Mar 22, 2016 4:38 pm Looking fantastic, keep up the good work. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 57Mar 24, 2016 9:06 pm Ohh very nice! Great idea with the tiles around the grass. I really like that idea. Are those the plants you'll put in? I love the colour and texture contrast between them all. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 58Mar 27, 2016 1:54 pm I love what you have done with your backyard! Cant wait to see the finished product Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 59Mar 29, 2016 10:53 am Thanks all cat_dunc Ohh very nice! Great idea with the tiles around the grass. I really like that idea. Are those the plants you'll put in? I love the colour and texture contrast between them all. Yes, the pavers around the grass will make it much easier for lawn mowing, and it looks nice too i think. Those wont be the exact plants i will put in, but the colours/shape/size will be similar hopefully. In the feature planter box (square shape with bench aroudn it) I am aiming to plant a Yellow/White Frangipani. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 60Apr 01, 2016 10:39 am Wrexter, well done mate. Looking really nice. Good to see someone plan out their design and work to that than just plonking stuff in and hoping it works. Really pays off and will be a great sense of achievement when your finished. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8569 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7403 |
