Browse Forums Landscape & Garden Design 1 Feb 17, 2015 8:24 am Hi All, I live on a sloped property consisting of 3 terraces. The lowest terraces is quite a dump but im looking at cutting it back a few meters and building s retaining wall. The current slops has plenty of broken shale rocks (big and small) and someone suggested making use of this and building a retaining wall using gabion baskets. Are there any major considerations you need to take when building a retaining wall using gabion baskets? Also, where can you purchase decent quality gabion baskets? Regards, Robbie Re: Retaining Wall using gabion baskets 2Feb 17, 2015 4:09 pm There are two sorts of gabions: The cheaper but still adequate gabbions that have a lighter mesh which is flexible. These don't look as good as: A heavier mesh such as the ones from this company http://www.gabion1.com.au/ which are better at retaining its shape. With Gabions you are building a 'Low Skill' drystone wall NOT a No Skill' wall. Just tipping the stone in won't give the best results, the stone should be stacked in the gabion leaving the minimum voids. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining Wall using gabion baskets 4Feb 17, 2015 8:12 pm Do post pics please! I'm thinking of using gabions too. Oh and prices for the rock whilst you are at it (please) Re: Retaining Wall using gabion baskets 5Jun 17, 2015 9:02 pm By using a lower gauge steel (such as 3mm), the baskets can tend to "bulge" if stacked more than 1 level high. The steel struggles to hold the rock/stone in a form the basket was meant to. I'd suggest looking at a minimum of 4mm for single storey stacking and if going more than 1 basket on top of another, go with 5mm to be safe. There are some good options available at www.gabionbasketsmelbourne.com.au if in Vic or www.gabionbasketsqueensland.com if in QLD. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5708 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16361 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7067 |
