Browse Forums Landscape & Garden Design Re: Steps to front door 8Sep 04, 2020 6:17 pm chennaiite Nickf Thanks for the reply What about 6 steps(7rises) rise 183mm step 830mm is there an optimum step would prefer longer step Should the step (run/going) be able to accomodate 1 or 2 footfalls (1foot on the step other foot on next step or both feet on step then climb to next step) Am I making this too complex??? I've no clue how I'm going to achieve this but this is how it's designed for my about to be built house. Mixed shaped risers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ chennaiite I think what you meant to say was different size goings. In modern landscaping it's common to mix a couple of steps with big landings of different sizes. It helps break up the look of the hardscaping. You will find that the risers will be the same height. The pictures below are a job I did a few weeks back. All the risers including the ones up to the front entrance are the same height, but once you are of the actual flight of stairs and into the hardscaping the landing sizes change. Looks like you even have some negative details on the risers which always look good. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4796 Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 25361 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 3410 |
