Water seeping through new slab problems
Essentially we have created a concrete bunker, shotcrete floor and walls with a bondek roof. Then regular concrete poured on the bondek for the top (used as a deck). For some reason when it hammers down with rain, water is seeping through on the internal walls... I'm just wondering what I can use to seal it up ... Is there some sort of expanding weather sealer or something I can caulk in? It seems to be sealed from the outside..
I'll attach some pics of the process.
https://imgur.com/27kuMS7
https://imgur.com/JKXqMDr
https://imgur.com/80TZEsL
https://imgur.com/MveITay
https://imgur.com/usPeZ7D
Stippo
Welcome to the forum
Check your certified construction and engineering drawings and details for a section marker
The engineering notes should mention Waterproofing
Unfortunately, Caulking is a temporary fix and won't last
Search Basement Waterproofing Membrane
Cheers
Chris
Hi Welcome to the forum
Cheers
Chris
What finish is on the top surface and is it completed yet?
we are experiencing a similar problem, with a mancave built in a similar style. Wondering whether you have resolved the issue?
7
Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further…
19/05/2023
3
yep sounds good make the footing bigger to to allow for the pipe in the middle
21/10/2023
Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the…
