Browse Forums DIY, Home Maintenance & Repair 1 Jun 25, 2022 3:28 pm Hi, I had just bought a new filter (image attached, link below) to replace in my Philips PowerPro vacuum and what I see now is that there is a gap (image attached) between the body and the dust container and the attached clip just wouldn't fit/click (image). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 5.92US $ 40% OFF|Best Sell Filter Set For Philips Power Pro Active And Compact Vacuum Cleaner. (comparable With Fc8058 / 01) - Vacuum Cleaner Parts - AliExpress Smarter Shopping, Better Living! Aliexpress.com [img=12x0]https://ae01.alicdn.com/images/eng/wholesale/icon/aliexpress.ico[/img] www.aliexpress.com Can somebody please help with a fix? I am unable to fit it completely, or else the motor is running just fine. Thanks, P. I am currently doing a bathroom renovation and want to put in a window that is narrow than the current one in a brick opening. Can I fit the window on the bottom noggin… 0 591 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 18020 ![]() Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 32002 |
